Coilovers , arch rolling advice
- controversial
This may not be for the purist but ..
I have a RS4 B7 ... Got masses of adjustment left but want the front lower , problem I'm having I won't be able to turn the wheels if I go lower on the front , rear is perfect . . Ok if I have the front arches rolled will this enable me to get that front wheel tucked into the arch ??
993 RS
RS4 B7
Nononsense Chopper
Harley Davidson Fatboy Custom
RS4 B7
Nononsense Chopper
Re: Coilovers , arch rolling advice
Yes. I had to do this as I'm quite low and using spacers.. It rubbed before.
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
Are you not concerned about the dreaded speed bumps ?
When I lowered mine it used to scrape the bumps unless I drove one side over them ( annoying )
So raised it no scraping
- controversial
Not at all bud .... If we worried about things like speed humps it's time to give up :- use alternative route or drive slow
993 RS
RS4 B7
Nononsense Chopper
RS4 B7
Nononsense Chopper
Don't roll the front arches. Have the lip that goes inwards removed. I run 20x10.5 inch wheels all round. That's what I had done. No rubbing whatsoever.
- controversial
Any photos of how low your car is ??
993 RS
RS4 B7
Nononsense Chopper
RS4 B7
Nononsense Chopper
Also how did you finish the edges off? Cheers
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
This is Davids car:controversial wrote:Any photos of how low your car is ??
viewtopic.php?f=35&t=101189&p=769790#p769760
Thanks Mike.MikeFish wrote:This is Davids car:controversial wrote:Any photos of how low your car is ??
Yes thx Mike for the link
Dave, Love the set up
How did they finish the arches edges off? Did they fold the lip back inside?
Do love that RS6 grill, what have you done about the number plate? Rich
RS4 B7 Avant,2007
highly recommend rolling the fronts!! cheap and very effective mod..and will eliminate 99.5% of rubbing!
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
What's involved mate and what's cheap mate ?RS4eddie wrote:highly recommend rolling the fronts!! cheap and very effective mod..and will eliminate 99.5% of rubbing!
RS4 B7 Avant,2007
well, I had a guy do it for $50 usd took him one hour. said the aluminum fenders weren't an issue at all, as some have stated.R1RS4 wrote:What's involved mate and what's cheap mate ?RS4eddie wrote:highly recommend rolling the fronts!! cheap and very effective mod..and will eliminate 99.5% of rubbing!
Nice piece of kit - simples
What did you do with the rear inner arches?
RS4 B7 Avant,2007
rears were fine..not needed. are you running in the back too??R1RS4 wrote:Nice piece of kit - simples
Users browsing this forum: Bing [Bot] and 74 guests
