Handsfree and bluetooth for B7 RS4
sjjhr
Post by sjjhr » Fri Jan 01, 2016 3:56 pm
Hello. I have a B7 RS4 with Bose Symphony system. Is there a way to (i) get it to pair with a modern phone to use the system handsfree? (ii) source music from an iPhone or digital device?
Many thanks in advance. S
PetrolDave
Re: Handsfree and bluetooth for B7 RS4
Post by PetrolDave » Sat Jan 02, 2016 5:55 pm
sjjhr wrote:Hello. I have a B7 RS4 with Bose Symphony system. Is there a way to (i) get it to pair with a modern phone to use the system handsfree? (ii) source music from an iPhone or digital device?
(i) Retrofit the OEM Handsfree kit which uses Bluetooth - this is how I connect my iPhone6+
(ii) (a) OEM method - replace the RNS-E with a 2010+ model and replace the CD changer with an AMI fitted with a Tune2Air Bluetooth adapter
(ii) (b) Non-OEM method - fit one of the aftermarket Bluetooth Aux In adapters.
sjjhr
Post by sjjhr » Sun Jan 03, 2016 9:53 pm
Thanks for your reply. I don't have the RNS-E - I have 6CD Bose Symphony CD head. Does anyone have a solution for my original questions please?
PetrolDave
Post by PetrolDave » Mon Jan 04, 2016 6:53 pm
sjjhr wrote:Thanks for your reply. I don't have the RNS-E - I have 6CD Bose Symphony CD head. Does anyone have a solution for my original questions please?
My answers (i) - if you have an MFSW - and (ii)(b) still apply to a Symphony II as fitted to a B7.
sjjhr
Post by sjjhr » Tue Jan 05, 2016 12:19 am
Thanks - have you used a particular supplier and fitter? I've looked at the head unit and it doesn't look easy to remove without damaging the console
RossDagley
Post by RossDagley » Tue Jan 05, 2016 11:54 am
sjjhr wrote:Thanks - have you used a particular supplier and fitter? I've looked at the head unit and it doesn't look easy to remove without damaging the console
There are 4 keys that slot in to remove (picture shows RNSE but same slots are on yours):
Previously:
sjjhr
Post by sjjhr » Tue Jan 05, 2016 12:00 pm
Thanks, appreciate the tips as I learn about this car
PetrolDave
Post by PetrolDave » Tue Jan 05, 2016 6:56 pm
Try and get the keys with plastic coating on the rings where you hold them - unless you like the sight of your own blood :bigblink:
Return to “Electrical”
Users browsing this forum: No registered users and 23 guests
