Hi All,
Wondering if anyone if able to help with an issue my car picked up yesterday.
Put my foot down coming off a round about when the ESP light came on and stayed on solid. Came up to a set of lights and it went off but came back on again when I pulled off.
After turning the car on and off again ESP was still on and also the engine light came on (both solid)
Got home and ran a scan with the below results. I've reset the codes but the ESP comes back again after around 30 seconds or when making a sharp turn. Engine light seems to come back on when turning the car on and off a few times.
I'm guessing a new MAF sensor but I've also seen online people talking about an ABS wheel sensor that could also be the issue? How easy are these to fit?
Car has been running fine and is still running ok now even with the errors on the dash.
Ill order a new MAF from TPS on Monday but anyone think it could be anything else?
1 Fault Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 54184 km
Time Indication: 0
Freeze Frame:
RPM: 1768 /min
Load: 31.0 %
Speed: 14.0 km/h
Temperature: 83.0°C
Temperature: 46.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.462 V
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B55DDB28A8EC366D3-807E
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x1EC0
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x01A7
Hex Value: 0x0001
ESP Light & Engine Light on. New MAF?
RS4 Avant - Misano Red
Re: ESP Light & Engine Light on. New MAF?
I'd say change the maf first, I think that will sort it out
Euro car parts are doing the sensor for £116 and if you use discount code VOUCHB10 or EXTRA10 it comes to £105.
No photo of item so can't verify it is the right thing though.
Bought this just over a month ago as i had a bit of an erratic idle that i thought it would fix, so i fitted it and it made no difference so i put my one back.
Had the car serviced and they reset the fuel trims and idle problem is gone.
The sensor was £144 from audi, you can have for £100 delivered if you're interested.
Thanks for the offer but I ordered one from TPS yesterday.ashy wrote:Bought this just over a month ago as i had a bit of an erratic idle that i thought it would fix, so i fitted it and it made no difference so i put my one back.
Hopefully this will sort it.......
New MAF fitted today, codes wiped and a 30 minute drive with no errors. Car seems to drive a lot better also.
Nice easy fix with the VCDS paying for itself once again.
Cheers all
Cheers all
Users browsing this forum: Majestic-12 [Bot] and 108 guests
