RS6 Plus transmission rebuild specialist in Midlands??
RichB888
Re: RS6 Plus transmission rebuild specialist in Midlands??
Post by RichB888 » Thu Nov 12, 2015 12:54 pm
yes for sure.
and they also use the auto transmission place that did the previous torque convertor rebuild last time.
Post by Shoppinit » Thu Nov 12, 2015 12:58 pm
Sounds like a better plan than an unknown place then.
Post by chunky79 » Thu Nov 12, 2015 7:04 pm
If you were going north then I'd pop into Unit20 and see grizz. Or, as you're in the Midlands just pop down to MRC.
jockthedog
Post by jockthedog » Fri Nov 13, 2015 6:29 pm
I've been learning a lot about these boxes recently, including tearing one down to the ground and about to rebuild it.
Be very careful driving around with this issue.
If it's a valve-body problem (sounds like it) it could lead to the A drum coming in contact with the C drum and that would damage the A drum and other parts and require a complete rebuild. Apparently that is a common issue.
Don't want to worry you :)
Capt Ric
Post by Capt Ric » Sat Nov 14, 2015 12:01 am
As Chunky said
"If you were going north then I'd pop into Unit20 and see grizz. Or, as you're in the Midlands just pop down to MRC"
MarkPRS6
Post by MarkPRS6 » Wed Nov 18, 2015 9:01 pm
Hi
Where is best place to get transmission filter kit? I guess Audi would be best but are there any independant suppliers with same quality? Dont fancy ebay for obvious reasons.
Daytona Grey RS6 with Miltek stainless exhaust and Bilstein coilovers, magic tree air freshener.
Previous : Porsche 911 Carrera 4
Capt Ric
Post by Capt Ric » Thu Nov 19, 2015 10:47 am
Unit 20 recently did mine, I think they only use VAG parts.
Parts were about £70 Oil about £90, labour about the same as 1 hour at Audi.
Unless you have the knowledge, time and equipment to DIY, why would you?
For info original box 50,000 approx 25,000 since last change no problems or noticeable difference before or after change, but Grizz reported oil was 'burnt , slightly dirty but not metal on magnets. Basically needed changing for preventative maintenance.
Post by Shoppinit » Thu Nov 19, 2015 11:15 am
MarkPRS6 wrote:Hi
I don't think it's worth the risk. There have been a lot of incidences of the wrong strainer being installed with nasty consequences (pick up pipe length differences).
You're looking at list prices of about £45 for the strainer and £25 quid for the sump gasket. The oil is pricey, but check the FAQ for equivalent oils at other brand dealers.
RichB888
Post by RichB888 » Tue Dec 01, 2015 2:51 pm
Thanks for the input.
Well an update, my car has been at the garage for a couple of weeks now,
tried an oil and filter change first, made no difference.
next thing is an gearbox ecu swap, but they've been on back order, one arrived today.
If that doesn't work then its out with the box and engine...
RichB888
Post by RichB888 » Tue Dec 01, 2015 3:16 pm
btw is it really gearbox AND engine out job, or can it be removed without taking the engine out as well??
Post by Shoppinit » Tue Dec 01, 2015 3:31 pm
It is not impossible to remove just the gearbox. But there is almost as much work involved as removing both at once. There is also a much higher risk of damaging something.
dave81uk
Post by dave81uk » Tue Dec 01, 2015 9:38 pm
Try Roger Bayliss transmissions in Cradley Heath
Very old school & knowleagble
01384 564844
07850399988
Tell him Dave Homer gave you his numbers he will sort you out
Cobalt
Post by Cobalt » Wed Dec 02, 2015 8:53 pm
Warranty Direct took my last RS6 to a place near Bedford and the did it without removing the engine. Was perfect after and I think they paid out about 2k. I was a few years ago though!
RS6 C5 05 plate very tidy.
Past.... Only have 500 characters ! RR Sport X 2 Nice but boring RS6 C5 03 Sold due to losing 25K of value in 12 months of ownership !
Still have a 72 GT6 and a few Big Bikes....
Covkiller
Post by Covkiller » Wed Dec 02, 2015 10:28 pm
Central Axles Brum
:nogarors4:
jangol
Post by jangol » Wed Dec 02, 2015 10:58 pm
Cobalt wrote:Warranty Direct took my last RS6 to a place near Bedford and the did it without removing the engine. Was perfect after and I think they paid out about 2k. I was a few years ago though!
Was it in St NEOTS by any chance??
