RNS-E AMI Upgrade
neilparf
Re: RNS-E AMI Upgrade
Post by neilparf » Tue Mar 31, 2015 7:24 pm
Irn_bru_ce - I fitted this: http://www.ebay.co.uk/itm/Audi-A4-S4-RS ... 3f1ecaee1a
With VCDS and the correct RNSe Keys form Ebay (item # 281330963594) was very easy. Sat Nav Deals actually do the switch out of the relevant parts to make the 2010+ work in a Rs4 - A3 inner to give you a later 2010 processor with an Rs4 fascia. Comes with a 'radio code' and with VCDS and this thread, dead easy...
The same money too and they switched the chrome nobs for the RS4 matt black knobs to keep it a totally OEM appearance. 1yr + on and no issues...
The fascia they use was totally blemish free - it was like new.
Gone but never forgotten:
C5ARK_RS4
Post by C5ARK_RS4 » Sun Nov 29, 2015 1:47 pm
I'm looking to do this upgrade in the new year.
Current set up is RNS-E pre 2010 and CD changer in the glovebox. I've been using a Dension for ipod connection which has done the job for the last 4 years - but isn't perfect.
I'm planning on selling the RNS-E on ebay and buying the mk2 post 2010.
I see on ebay you can buy 2nd hand AMI for £100 however there's no mention of cables.
Can someone give me a link to which cable I would need to connect RNS-E to AMI. The previous link on page 4 of this thread isn't working any more.
Also, are there any other cable's required? (except required connection cable from ipod to AMI)
I know about changing face of 2010 RNS-E and will probably buy from eBay recommended in this thread so it comes with the conversion already done. Am I missing anything else?
Thanks. Ian.
Surrey Sam
Post by Surrey Sam » Sun Nov 29, 2015 7:47 pm
I can't comment on the Kuftec cabling option, as I used Audi stuff when I did mine.
You need:
2010+ RNSe
CAN version of AMI
Cable - 8K0 051 592
Connector - 1J0 972 977 G
iPod and USB Adaptor set - 4F0 051 510 P
Re-code modules
You do have to re-pin the cable with the 32pin connector on one end and then splice the other into the wiring harness. The kuftec option, may or may not eliminate having to do all of that?
davers6
Post by davers6 » Sun Nov 29, 2015 10:03 pm
I got a plug and play harness from German eBay can get you the item number if you need it
C5ARK_RS4
Post by C5ARK_RS4 » Sun Nov 29, 2015 10:56 pm
Thanks for the info Sam.
I thought there may have been just one cable without having to re-pin/splice etc.
Dave, can you let me know the German item number for the plug and play.
Many thanks. Ian.
davers6
Post by davers6 » Mon Nov 30, 2015 9:14 am
Yep 191133285956
ians63
Post by ians63 » Wed Jan 06, 2016 11:04 am
Just about to push the button on this. I have the RNS-E 2010 and AMI and all wiring to fit.
Can someone confirm what the correct VCDS coding should be for the new set up - current code is 0309753.
I've been onto ross tech wiki pages so it's probably me just being thick!!
Surrey Sam
Post by Surrey Sam » Wed Jan 06, 2016 11:46 am
I have my 193 H model as 0309723 which was coded for Bluetooth, AMI & CD changer.
The loom was wired for both AMI & CD changer, as I had planned to run both together in a custom glove box but lost the urge to carry the idea through. It throws a fault code when one of them is not connected but it does allow me to change between CD Changer and AMI should there be a requirement to do so.
marc1
Post by marc1 » Wed Jan 06, 2016 12:41 pm
ians63 wrote:Just about to push the button on this. I have the RNS-E 2010 and AMI and all wiring to fit.
Pretty sure you change the second to last digit to '2' from memory. As long as you've got the current code written down you can revert back to it if there's a problem. Once the coding change has been accepted you'll need to reboot the RNSE by pressing and holding down 'setup' and 'radio'.
PetrolDave
Post by PetrolDave » Wed Jan 06, 2016 6:45 pm
Surrey Sam wrote:I have my 193 H model as 0309723 which was coded for Bluetooth, AMI & CD changer.
I have a 193 C model and have coding of 0309721 as I don't have the CD changer included.
The Ross-Tech wiki gives coding details http://wiki.ross-tech.com/wiki/index.ph ... 28RNS-E%29 which shows the correct coding for AMI now.
marc1
Post by marc1 » Wed Jan 06, 2016 7:03 pm
Interestingly that shows an RS4 start up screen in channel 018.
Post by MikeFish » Wed Jan 06, 2016 7:21 pm
Marc, isn't that because it is a generic RNS-E info page and not specific to the 2010+ model?
PetrolDave
Post by PetrolDave » Wed Jan 06, 2016 7:27 pm
MikeFish wrote:Marc, isn't that because it is a generic RNS-E info page and not specific to the 2010+ model?
Yes.
There is no coding page specific to the 2010+ model.
marc1
Post by marc1 » Wed Jan 06, 2016 8:01 pm
Oh well. Not like there isn't enough RS4 logos everywhere. :lol:
CaptainLeadFoot
Post by CaptainLeadFoot » Fri May 19, 2017 6:29 pm
Finally ordered the 8P0 AMI and the Shop is shipping next week.
Just wondering if anyone is keeping both CD stack and the AMI in the glove box, or just put the AMI there ?
With the CD stacker out, do I need to shield the CD stacker connector to avoid it picking up interference ?
Users browsing this forum: Google [Bot] and 92 guests
