diff ratios
thworks
diff ratios
Post by thworks » Sun Nov 22, 2015 7:36 pm
hi all, recently bought an rs6 avant 2004 and love it. however the pinion bearing in my rear has taken a turn for the worse. i picked up a second hand diff yesterday, went to fit today but i have different ratios. anyone know if there are different ratios fitted to the rs6. i have a 3.2 in my car and was supplied a 4.1 as an rs6 diff.
thanks in advance
Re: diff ratios
Post by Shoppinit » Sun Nov 22, 2015 7:51 pm
FON
You should have a 3 letter code stamped on the diff housing. There are 4 different codes with 2 different ratios. Which one(s) have you got?
thworks
Re: diff ratios
Post by thworks » Sun Nov 22, 2015 8:08 pm
what is this FON??
is it the code on the alloy part of the bottom of the diff, if so both have the code but different ratios.
thworks
Re: diff ratios
Post by thworks » Sun Nov 22, 2015 8:12 pm
both have jkp stamped on them
Re: diff ratios
Post by Shoppinit » Sun Nov 22, 2015 9:29 pm
Should be 3 letters followed by 5 numbers.
thworks
Re: diff ratios
Post by thworks » Mon Nov 23, 2015 8:30 am
thanks, have you got the codes and relevant ratios to hand? done endless searching but not come up with anything.
Re: diff ratios
Post by Shoppinit » Mon Nov 23, 2015 11:25 am
DSA xxxxx : 37:9 -> 4.111
EUS xxxxx : 37:9 -> 4.111
DUR xxxxx : 37:10 -> 3.700
EUU xxxxx : 37:10 -> 3.700
What happened to the hotlink on FON?
FON
thworks
Re: diff ratios
Post by thworks » Mon Nov 23, 2015 1:46 pm
thanks I'll have a look for the code, strange that mine measures as a 3.2:1 though.
Re: diff ratios
Post by bam_bam » Mon Nov 23, 2015 1:50 pm
ahoooga
Re: diff ratios
Post by ahoooga » Mon Nov 23, 2015 6:18 pm
FON :beerchug:
but the hotlinks gone :(
thworks
Re: diff ratios
Post by thworks » Mon Nov 23, 2015 8:04 pm
Ok so the only code I can find is ggw followed by 6 numbers. On both diffs. Some googling seems to suggest this is 3.19 ratio which is what I have.
Anyone know about this code?
Re: diff ratios
Post by Shoppinit » Mon Nov 23, 2015 8:14 pm
Mmm. Found some more info. GGW is the final drive code for the RS6. Looks like it was only fitted to the RS6. The ratio is 37:9.
Re: diff ratios
Post by Shoppinit » Mon Nov 23, 2015 8:18 pm
I can't find any 3.2 diffs on the RS6 era quattro cars. Where are you getting that from?
thworks
Re: diff ratios
Post by thworks » Mon Nov 23, 2015 9:14 pm
Ok, I'm going to pull the bottoms of both tomoz so I can count the teeth to see what's going on for sure. Thanks for all the help.
thworks
Re: diff ratios
Post by thworks » Wed Nov 25, 2015 7:24 pm
So took the diff out last night and stripped it, thankfully had 37/9 ratio, pinion bearing was really seized so getting the wrong reading when working it out from spinning pinion x times to 1 rev of output. New diff in and all good!
Nice one for the help, much appreciated
Users browsing this forum: Google [Bot] and 91 guests
