Further to Ross's post here viewtopic.php?f=47&t=114989
I had the brake ducts fitted today and apparently it was extremely easy and all that was required was to elongate the bottom hole to allow the bolt to line up correctly.
Hopefully they will help with disc life as I'm on my third set in 4 years of ownership.
Brake ducts
Re: Brake ducts
Forgive my uselessness... I assume these are to direct airflow directly to the discs etc or similar is it for extra cooling?
Re: Brake ducts
Apologies for late repy Av4nt - yep these are just to capture a little more air and shove it on the back of the disc. Always a good idea in case a bit of heavy braking is needed (its not a light car) especially if you're thinking of doing the odd bit of trackdaying like you said in another post.
Written-off: Night Blue Metallic S6 5.2 V10 - Private plate, LED interior kit.
Sold:
Hibiscus Red Metallic S4 (B5 99.5) w/AmD Stage 1 Remap, RS4 Exhaust w/ Gutted Precats & R32 Tailpipes, Afterun Sensor, H&R Coilovers
Sold:
- RossDagley
- Top Gear
Re: Brake ducts
Great simple mod - pleased to have helped
I actually have a set of backplates and ducts brand new never fitted (as they're not a direct fit to the B8 and I was looking at fitting them to that) so if anyone wants them, I'm a PM and a haggle away...
Previously:
Previously:
