DRC noise under normal operation
4.2 V8 32v FSI - 444 bhp
carsarecool
Re: DRC noise under normal operation
Post by carsarecool » Thu Nov 12, 2015 6:26 pm
RIV wrote:
point missed......but now expected./quote]
Basically your saying that because the golf rattles more than the RS
It's acceptable to put up with the knocking on your car?
LOL, I was half expecting that, do you copy everything I post just so you can regurgitate?? weird but hey..I deleted that as I wanted to replace it with whats below....more words for you to take in......
"RIV, let me put it another way so you might get the point I was making. I was simply saying I think mine knocks now and again but it isn't as bad as a Golf which in reality isn't "noisy" per se.
I think may be the UK's roads can be held equally responsible for much of this knocking."
RIV
Post by RIV » Thu Nov 12, 2015 7:10 pm
No you are missing the point!! I have aVW T5 for work it drives perfectly with no knocks, that's done 100k
Why should we put up with the DRC knocking, I don't think it's acceptable that Audi say it's a normal trate of the car. If my van did the same I would be getting it looked at.
carsarecool
Post by carsarecool » Thu Nov 12, 2015 7:13 pm
From what you've said you don't have to :) So the van makes no noise going over bumpy surfaces whatsoever....maybe you are deaf :)
RIV
Post by RIV » Thu Nov 12, 2015 7:25 pm
I guess your the Dumb one
carsarecool
Post by carsarecool » Sat Nov 14, 2015 10:59 pm
Whatever you say fella
boff
Post by boff » Mon Nov 16, 2015 12:28 am
Just throwing this out there, The RS6 I've just had on Air with no DRC knocked a bit. I think I am getting used to this what is normal thing.
Technically if you think about it, something has to absorb the hits, you are asking for a 1700kg thing to hit a pothole with 35 profiles on 20's and just suck it up, with the added complexity of a hydraulic roll bar system.
NOW - before you flame me, I know that there are cars which are knocking more than most - and I know from personal experience with my C5 that you can get faulty DRC which leads to significantly more knocking and that needs to be fixed.
But going back to the Van, we are talking possibly higher flex in the tyres and conventional spongy springs and dampers.
It's like saying because my golf plus doesn't knock the RS4 shouldn't.... erm yeah but I'd never take the Golf around the ring in sub 8 minutes.
Of course then you have mag ride - which will probably not knock!! argh!
Zero Drama
RossDagley
Post by RossDagley » Mon Nov 16, 2015 12:36 am
Are you sub 8 in an rs4 boff? I'd like to see that :)
I'm hoping for 8:00-08:15 times this year in mine.
Previously:
boff
Post by boff » Mon Nov 16, 2015 1:27 am
RossDagley wrote:Are you sub 8 in an rs4 boff? I'd like to see that :)
You'll smash it - just be careful!
Zero Drama
RossDagley
Post by RossDagley » Mon Nov 16, 2015 8:13 am
Lol The car is capable I'm just not sure I am!
Previously:
carsarecool
Post by carsarecool » Mon Nov 16, 2015 8:22 am
boff wrote:Just throwing this out there, The RS6 I've just had on Air with no DRC knocked a bit. I think I am getting used to this what is normal thing.
At last, sensible comments. Suspension will never be silent. I think you are either tuned into the noise or not.
will1981
Post by will1981 » Mon Nov 16, 2015 11:07 am
1700Kg? With a full tank my B8 RS4 weighed in at 1930Kg. :thumbs:
2016 BMW F80 M3
2014 B8 RS4 - Milltek Non-Res - KW V2's with DRC delete - Setup by Centre Gravity. - Sold
2013 Q5 2.0 Tdi
1997 BMW E36 328i track car
RossDagley
Post by RossDagley » Mon Nov 16, 2015 11:35 am
carsarecool wrote:At last, sensible comments. Suspension will never be silent. I think you are either tuned into the noise or not.
You've clearly never been in a car with a DRC knock. It's not exactly subtle. It's like someone using a mallet on the inner wheel arch. It is NOT like the noise you'd associate with a pot hole, nor like the noise you'd accept/expect from an old and used cheap vw...
Previously:
RIV
Post by RIV » Mon Nov 16, 2015 11:58 am
It's like a hollow clunking sound, can be worse driving over very small undulations in the RD
I had my B7's DRC replaced 3 times before I ripped it out for coilovers. If it's bad it can put you off the car tbh
RossDagley
Post by RossDagley » Mon Nov 16, 2015 12:04 pm
RIV wrote:It's like a hollow clunking sound, can be worse driving over very small undulations in the RD
This (on both counts).
It's generally worse on "bumpy" ground as you say - a full on pothole you'd expect a noise from.
It's certainly detracted from the supposedly lovely experience of buying a new car for me :(
Previously:
RIV
Post by RIV » Mon Nov 16, 2015 2:32 pm
I don't blame you for being pissed off, especially after having to take of that lovely exhaust system :audibash:
