My car is doing my nut in!
5.0 V10 50v biturbo - 571 bhp
AudiPartner
Post by AudiPartner » Fri Oct 23, 2015 9:26 am
Since the car came back from Audi (coincidence) the tailgate hasn't opened fully, and as such I keep banging my head!! :thumbsdown:
Has anyone had this? Is it just worn/tired struts? It's not all the time but more often than not.
MNK
Re: My car is doing my nut in!
Post by MNK » Fri Oct 23, 2015 11:22 am
Could just be cos it's cold now...
Ungjaevel
Post by Ungjaevel » Fri Oct 23, 2015 12:03 pm
Mnk : cold... Why would that cause an issue?
MNK
Post by MNK » Fri Oct 23, 2015 1:04 pm
actually ignore that... i'm guessing we're talking about an estate here not saloon. not sure how the estate boot works.
on the saloon the boot is opened by gas struts, so the pressure in them will vary with temperature. in the winter my boot hardly opens when i unlock it... in the summer it opens fully without me touching it.
F15HAR
Post by F15HAR » Fri Oct 23, 2015 2:12 pm
Have you tried the height reset as per the manual? I think it was basically lift/push to the correct height and depress the button on the tailgate for 5 seconds or so and that stores the new height...
AudiPartner
Post by AudiPartner » Fri Oct 23, 2015 4:05 pm
F15har wrote:Have you tried the height reset as per the manual? I think it was basically lift/push to the correct height and depress the button on the tailgate for 5 seconds or so and that stores the new height...
nice one, will look it up and give it a try! :thumbs:
leet
Post by leet » Sun Nov 01, 2015 8:08 pm
Did this work?
AudiPartner
Post by AudiPartner » Thu Nov 05, 2015 2:45 pm
Did this work?
It didn't no.
The procedure was to open the boot to the desired position and then hold the close button down for 4 seconds and it stores the position in the memory.
But I guess this only applies if you want to set it at less than it's maximum. My issue is that it seems to only open say 90%.
TomRS
Post by TomRS » Mon Nov 09, 2015 12:33 pm
I have this issue also, it won’t open the full 100% only goes 90% as you say, tried the height reset but that doesn’t work.
It’s had new boot struts so it’s not them either, unsure how to make this work? Live with it?
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
AudiPartner
Post by AudiPartner » Tue Nov 10, 2015 10:30 am
Tomj333 wrote:I have this issue also, it won’t open the full 100% only goes 90% as you say, tried the height reset but that doesn’t work.
if i pull my finger out and get the car booked in to Audi again then i'll let you know what was done to resolve it. :thumbs:
Users browsing this forum: Ooonst and 35 guests
