Hi - anyone had any experience of hot starting problems? Mine bursts into life immediately when cold. When hot, often wont start first time, sometimes taking 2 or 3 attempts. Then sort of splutters into life.
Absolutely no problem at all once running, and shows no sign of any other problems. Its only when restarting from hot. Was thinking could it be an exhaust issue, with a build up of crap in there, preventing a clear path when restarting (ive had some odd rattling coming from the front part of the exhaust system, gone now).
Any ideas? Should I be worried?
Jonno
Hot starting problems
Re: Hot starting problems
Air temp/water temp sensors can sometimes cause this as can MAF, as the mismatched info confused the ecu putting in too much fuel causing a hard hot start.
Just an idea, dont own one so cant comment properly
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
Either the crank position sensor or fuel pressure regulator.
Does it have Cats?
OK many thanks chaps
Cats, not sure, how do I check?
I had the exact same problem. Would turn over until the 3rd attempt then splutter and need a Rev to start. Only did it when warm. Mine has a decat and I was told it could be the pre cat warmers telling the car to fuel incorrectly. Have since only changed the back boxes and don't seem to have a problem. Think it just passed with time.
Users browsing this forum: No registered users and 62 guests
