Hot starting problems
Jonno1888
Post by Jonno1888 » Thu Nov 05, 2015 3:46 pm
Hi - anyone had any experience of hot starting problems? Mine bursts into life immediately when cold. When hot, often wont start first time, sometimes taking 2 or 3 attempts. Then sort of splutters into life.
Absolutely no problem at all once running, and shows no sign of any other problems. Its only when restarting from hot. Was thinking could it be an exhaust issue, with a build up of crap in there, preventing a clear path when restarting (ive had some odd rattling coming from the front part of the exhaust system, gone now).
Any ideas? Should I be worried?
Jonno
TomRS
Re: Hot starting problems
Post by TomRS » Thu Nov 05, 2015 3:55 pm
Air temp/water temp sensors can sometimes cause this as can MAF, as the mismatched info confused the ecu putting in too much fuel causing a hard hot start.
Just an idea, dont own one so cant comment properly
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Post by Shoppinit » Thu Nov 05, 2015 4:33 pm
Either the crank position sensor or fuel pressure regulator.
LooseAsAGoose
Post by LooseAsAGoose » Thu Nov 05, 2015 6:39 pm
Does it have Cats?
Jonno1888
Post by Jonno1888 » Thu Nov 05, 2015 11:04 pm
OK many thanks chaps
Cats, not sure, how do I check?
LooseAsAGoose
Post by LooseAsAGoose » Thu Nov 05, 2015 11:09 pm
I had the exact same problem. Would turn over until the 3rd attempt then splutter and need a Rev to start. Only did it when warm. Mine has a decat and I was told it could be the pre cat warmers telling the car to fuel incorrectly. Have since only changed the back boxes and don't seem to have a problem. Think it just passed with time.
Users browsing this forum: Google [Bot] and 44 guests
