EGT sensor faulty.
bilko1
EGT sensor faulty.
Post by bilko1 » Sat Oct 31, 2015 1:24 am
I have an intermittent fault with my passenger side EGT sensor according to VCDS, will this cause the ecu to limit power? No engine management light comes on when driving. I did watch live readings and when the exhaust temp gets to 395 degrees the reading from the passenger side shoots up to 1100 degrees. This 1100 degrees seems to be a default reading or substitute value as if you disconnect the sensors when running the reading immediately go to this value.
After a bit of googlling it appears Audi EGT sensors are pretty poor quality due to the laws about lead free solder. My sensors were replaced when I had the gearbox rebuilt so would be the newer lead free versions which have only lasted 10,000 miles. Unfortunately they are out of the 2 year Audi parts warranty so I'm going to try and get to the circuit board and hopefully fix it. Am I right in thinking the RS6 EGT sensors are wideband? If so that's a shame as some Motorsport company in Poland make replacement circuit boards but from what I can tell ( I can't read Polish) they are not wideband.
Re: EGT sensor faulty.
Post by Shoppinit » Sat Oct 31, 2015 11:00 am
I have heard of people having success reflowing the solder on the boards.
Dave McB
Post by Dave McB » Sat Oct 31, 2015 12:34 pm
The polish guy's new boards are supposedly ok.
There is however a few weeks of back order - iv got the next set due.
I may not need them so if you want them i'll sell you them once they arrive
bilko1
Post by bilko1 » Sat Oct 31, 2015 10:45 pm
Thanks Dave, after a bit more Googling I have managed to contact the Polish guy (Sid) so I've bought a pair. Next question how do I get black goo out of the sensor box without destroying the circuit board / connectors ? Is there a magic chemical that dissolves it ? I'm a bit annoyed at myself for buying new Audi ones when I had my Gearbox done, the original ones are a lot easier to remove the board out of. Hindsight is wonderful.
Post by Shoppinit » Wed Nov 04, 2015 12:01 pm
I wonder what they use. Does it chip? Or is it rubbery? I'd try and get a bit of and then try dissolving it in the usual suspects: acetone, Isopropyl Alcohol, thinners, white spirit, petrol, etc.
lswing
Post by lswing » Sat Nov 07, 2015 5:51 pm
You can open them up and fix the solder, works most of the time. Someone just did a full write up with pics on rs6.com.
Revo Tune + extra ME7 fueling - MTM TCU - Wagners - Koni Struts - DevilSown W/M - Michelin PSS's - Hotchkis Sways - Upgraded TC/Trans - Mugello/Black/Carbon
Mɐʇʇ
Post by Mɐʇʇ » Sat Nov 07, 2015 6:47 pm
Yeh, I read that thread. A good how-to guide. :)
Post by Shoppinit » Fri Nov 13, 2015 5:48 pm
bilko1 wrote:how do I get black goo out of the sensor box without destroying the circuit board / connectors ?
How'd you make out?
bilko1
Post by bilko1 » Sat Nov 14, 2015 3:33 pm
Circuit boards have turned up, just waiting till I get a day off to have a looksy.
Users browsing this forum: asgor, Bing [Bot], srichards, steve2003rs6 and 84 guests
