2008 RS4 not starting
njp
Post by njp » Fri Oct 30, 2015 8:37 am
Hoping someone may be able to assist. Just picked up a 2008 Avant RS4 in great condition but I have an intermittent issue that's annoying to say the least.
On startup the car won't start, key in ignition to start or on whichever it's called and the Engine lights in the upper dash doesn't light up which means the start button doesn't function. The thing is in the four days of ownership it happened the day of pickup and then started again after 5 min, again yesterday where she wouldn't start for 2hrs I then had a new battery installed and the car started for the installer first time before he changed the battery, changed it anyway as it was old. I've also changed the key fob battery.
Locked the car up last night in the garage and then this morning no issues starting it.
Took it to the mechanic who scanned and found a low voltage code and a low key battery code but nothing else, head off to a lunch meeting and get back to the car about 2hrs later and nothing. Call roadside assist who come out and initial can't make it start. He checks voltage, that's all good, he checks the lights they work and high beam lights up no problem including the in dash symbol, the stereo works no issues as well but no engine lights or start and the windows won't open. He then hooks up the jump cables and the car starts first time.
He seemed to think it was something in the ignition circuit either a loose relay or connection but couldn't say.
So the car is now in a garage to be diagnosed but has anyone here had anything similar or any idea what may be the fault??
Apart from this issue loving the new car though...
S4WON
Re: 2008 RS4 not starting
Post by S4WON » Fri Oct 30, 2015 8:45 am
Sounds like its immobilised.. Any after market alarm installed?
njp
Post by njp » Fri Oct 30, 2015 8:50 am
Not that I'm aware of but will check with the dealer I purchased off
njp
Post by njp » Fri Oct 30, 2015 8:58 am
S4WON wrote:Sounds like its immobilised.. Any after market alarm installed?
Checked and told its the OEM system.
S4WON
Post by S4WON » Fri Oct 30, 2015 9:33 am
Well, as you bought it from a dealer, id be tempted to return it. It certainly isnt normal behaviour....
Wheres his help in this? Or has he wiped his hands of it already?
njp
Post by njp » Fri Oct 30, 2015 9:50 am
He's helping. The mechanic is his. Thankfully second hand cars here from dealers come with a legal warranty for 3 or 5 months I can't remember which. So I have a loaner from the dealer or a horrid little BMW 1 series diesel at the moment.
S4WON
Post by S4WON » Fri Oct 30, 2015 9:51 am
Ah ok. Kick back and relax then, someone with more technical info may be able to give you some ideas.
Where are you based?
njp
Post by njp » Fri Oct 30, 2015 10:13 am
I'm based in southern Sydney near Cronulla beach.
DavidRS4
Post by DavidRS4 » Fri Oct 30, 2015 12:04 pm
I hope you are pushing the clutch all the way in?
njp
Post by njp » Fri Oct 30, 2015 12:58 pm
Yep the clutch switch isn't the issue. When it happens the car doesn't get to that stage of startup
Chargedrs4
Post by Chargedrs4 » Sat Oct 31, 2015 10:56 pm
in the front driver ecu box replace the n 614 relays ,easy fix
one and only street twin turbo rs4 b7 in the world with 640 plus awhp and 520 awtorque at 11.7 psi
800 plus bhp
njp
Post by njp » Sat Oct 31, 2015 11:09 pm
Chargedrs4 wrote:in the front driver ecu box replace the n 614 relays ,easy fix
Will get the mechanic to give it a try on Monday. Thanks.
kd
Post by kd » Thu Dec 31, 2015 10:10 pm
Not sure if you had this resolved but mine did the same and it was the starter motor I think. Everything lit up like normal with the key turned and the car would start sometimes when pressing the start button straight away and sometimes it took an hour or so. It turned out to be this and since being changed its all good. This was the part no (V079 911 023 DX)
njp
Post by njp » Fri Jan 01, 2016 12:27 am
Thanks. Not sure what the issue was but they fixed it while I was away for work. Smooth sailing from here on in.
RIV
Post by RIV » Fri Jan 01, 2016 1:17 am
+1 happened to my old b7 cheap and easy fix
Users browsing this forum: Google Adsense [Bot] and 96 guests
