Time for new brakes
Time for new brakes
HI all you knowledgeable people.
Well its brake time, as much as I want to go ceramics I want bigger wheels more so just need to change whats on there.
So I have a set of new discs OEM ones, but what pads and brake fluid are you guys all using?
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
Re: Time for new brakes
Andy, stick with OEM pads for feel. ATE super blue fluid and Hel brake hoses.
- Shinobi675
- 5th Gear
I spent a while looking. Ap racing is a middle ground between oem and ramics. But basically people reckoned it wasn't the leap you'd want for the extra cost, I think they worked out at twice the cost of oem all round.
Cheers guys,
Will order up today then.
So without ceramics is it oem ?
Not be long before my car needs fronts doing, cant see AP discs lasting long on theses barges
They didn't last long on my evo
The pagid rs pads were good though, anyone tried these, if available
If you want improved stopping power over the oem 390mm steels, but don't wish to spend the pounds on a ceramic upgrade but can afford a bit more than oem discs, I can highly recommend the MTM 405 mm steels front brake upgrade. Noticeable improvement in ability to pull the beast down from serious speed- 160mph+.
http://www.mtm-online.de/en/Audi/RS6-C6 ... s6bre405vk
just my two cents worth.
cheers,
john
cheers,
john
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
£2.5k for 2 discs though, jesus
I know you cant spend enough on something that stops the car well but
Just wondered if anyone has tried different pad combos , not fond of DS2500 or DS3000
Might get some Pagid's and try them
- Shinobi675
- 5th Gear
You so canadamgt wrote:£2.5k for 2 discs though, jesus
I know you cant spend enough on something that stops the car well but![]()
Trust me, you will feel the difference with the 405mm front steels
I went for ceramics all round in the end. One word, phenomenal!
kent_andy wrote:I went for ceramics all round in the end. One word, phenomenal!
andy did you buy brand new or s/h?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
I bought 2nd hand from ebay.de.
they had 18km on them, so like new, calipers were repainted satin red, but I believe kevin who bought it off me has now had them resprayed grey,
Can vouch for the performance of the ceramics. Absolutely phenominal.
I did send the calipers of to Godspeed but they were appalling. Had them 3 weeks and did bugger all to them due to the fact they were too big to fit in the powder coating oven. Never thought to call or email me. After a lot of chasing managed to get them back a month and a half after they got them. They did however manage to machine new stainless pistons and get a new seal kit. I have now had a local company sort the powdercoating which I pick up tomorrow then need to reinstall the brakes back onto the car. Hopefully this better sort the squealing...
So, if you can stretch to getting ceramics, do it.
C6 RS6 Saloon - Daytona Grey - ceramics, stage 2, gearbox map, quad tip miltek, pre cat delete and Mrc filters = 753ps + 1052NM ex kent_andy
1955 Chevrolet BelAir - 5.8 Lt1 + Procharger = 545bhp
If they're squealing, you aint using them hard enough!
I run AP Racing discs on the rear with DS2500 pads, Tarox 400mm discs up front with Tarox medium compound pads with ATE Super Blue fluid.
I cannot complain at all about the performance, the 16 pot fronts stop the car well and from the few 120mph to 0 stops I’ve done in quick succession enough to have both front and rear discs glowing cherry red, I suffered no brake fade at all.
As for the cost of Ap rears even with the initial outlay of the bells I got them for £696 delivered from BG developments.
They have been on the car a while now and there is no disc wear or “lip” as of yet and I’m not exactly a fanny when it comes to using the brakes, the fronts are the same although next time round I won’t be using tarox discs as they are just too costly just over £1000 for two front’s.
I will be replacing with either AP or Alcon’s depending on BG as with it being a custom Tarox bell the discs will be custom made.
To answer really all I can say is I like the DS2500 pads as a rear setup wear and feel is great as with the AP disc, when running standard pads as good as they were at quickly dissipating the heat and returning to good feel pretty quick I wasn’t happy with the heat retained in the discs and the pads started to break away after a few track days.
The tarox setup is great, it’s nowhere near as good as ceramics but I got the full kit with brand new pads for cheap. I think I’m as close as I can get to ceramics without actually moving to them.
Having used a friends porsche with ramics I prefer my initial bite but continuous use is second to none and heat management is far superior on the ramics, it’s something I’ll upgrade too in the future.
But to the OP I’d say AP discs and DS2500 are a very good/better than OEM replacement, I’d run Pagid RS-19 or 29’s in the front instead of DS2500’s however.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2010 Nissan GT-R SVM 680R
