Hello!.... Now an owner of a C5 RS6 Avant
Just a quick hello. I'm Harz. I'm currently looking for a C5 RS6 Avant. Been to see 2 so far, but no joy yet.
Re: Hello!
Welcome to the forum, the C5 section on here is always pretty active so you've come to the right place!
Good luck with your search, make sure to show us some pics when you find the right one
Re: Hello!
Cheers. I've been lurking as a guest for a couple of months. Found the buying guide/FAQ sticky very informative. So I thought I should sign up to the forum. I've been umming and urring for about three months wether to go for the C5 RS6 Avant or not and finally decided to view some. Saw two on the weekend. The first one had a few bits that started alarm bells ringing and my instinct was to walk away, which I did... It was a shame coz it was a 4 &1/2 hour round trip that I got my brother to drive me and it was a waste as I didn't want to take it for a test drive no where near as "immaculate" as it was made out to be. The second one was very clean and drove very well, but after the test drive it died and wouldn't restart. So the search continues. Now that I've driven one I'm set on getting one. I just have to be patient and wait for the right one to come around.SuprSi wrote:Welcome to the forum, the C5 section on here is always pretty active so you've come to the right place!
I'm currently driving a MK5 Golf GTI that I've had remapped to a custom Stage 2 map.
Re: Hello!.... Now an owner of a C5 RS6 Avant
Went on a looooong drive last weekend and picked up an 03 C5 RS6 Avant in Daytona Grey. It seems like a good one so far, drives well and looks great. I scanned it with VCDS and the only fault coming up is for the navigation because it's been removed. It has had quite a few owners and has just under 130k on the clock, but it's had a lot of money spent on it and seems like it's been looked after. It had a replacement gearbox in 2013 fitted by AMD and hasn't done much mileage in the last year or so. Being a 12 year old car there are a couple of niggles that need sorting:
There seems to be a bit of friction on the brakes and get a low squeal sound at normal driving speeds.
After a bit of hard driving the brakes squeal at an embarrassingly loud high pitched level.
The liquid in the rear view mirror has leaked so will need replacing.
It sounds like one of the rear speakers has seen better days, the CD changer and (I think) the Bose amp have been removed.
The drivers door doesn't close sometimes I think the latch in the mechanism is shot.
The navigation has been removed and replaced with a pioneer double din.
I can't change the date or time on the dash (I'm guessing because the navigation system has been removed, the menu knob by the handbrake does nothing maybe for the same reason)
It has had some modifications... Wagner intercoolers, Milltek cat-back, Billstein Coilovers. The previous owner said it had a stage 2 MRC remap (and gearbox remap) and was tuned to 520BHP. There is an invoice for a MRC remap, but no dyno print out in the paperwork to back this up. It does go though
Welcome along. Pretty sure the owner of that was on here. Think it was Eddies, or did that one get stripped for track use?????
It's had quite a few owners so chances are at least one of them was a forum memberchunky79 wrote:Welcome along. Pretty sure the owner of that was on here. Think it was Eddies, or did that one get stripped for track use?????
After a bit of googling found out how to adjust the date and time on the dash. Only a minor thing, but at least its sorted. It's a pain not having the owners manual.
Welcome!
Daytona RS6 Avant
Had a puncture last week and on taking off the wheel discovered that the CV boot was split.
As I didn't know how long the boot had been split for and that a new CV joint kit was only £36 I decided to get the joint and boot changed.
Was happy that I got the CV joint sorted, but when I arrived at my friends house for him to do the work the car decided to spring a leak as I reversed into his garage.
After the CV joint was done we took the under tray off to see where the oil was leaking from. The pipes on the oil/transmission fluid cooler have corroded and cracked.
Also got a problem with my drivers side headlight. Checked the fuses and changed the HID bulb, but still not working so looks like it could be a ballast or igniter.
Managed to get a second hand rear view mirror which will save me a lot of money as Audi want £209 for a new one! Also got a used Bentley books manual from the states. Find these cover a lot more than Haynes. Got a used door lock hopefully will cure the intermittent problem with the drivers door latch.
Users browsing this forum: No registered users and 71 guests
