Exhaust rattle on cold start
Hard to describe the noise, but its like a tin rattle from exhausts on cold start.
Only lasts bout 30 sec then clears. Doesnt do it on warm. Ive found a few threads about it, some say thats just the way it is, some say they had bits changed.
Anyone had personal experience?
Is a 14 car with 9k
Cheers!
Is a 14 car with 9k
Cheers!
Re: Exhaust rattle on cold start
mine is 2013 always is a bit rattly from cold but as you say less than 30 seconds and its gone personally nothing to worry about as it seems to be normal
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Mine's the same...Brooner wrote:mine is 2013 always is a bit rattly from cold but as you say less than 30 seconds and its gone personally nothing to worry about as it seems to be normal
Probably the exhaust valve flap. Get your ear close and see if it's present on one side or both. Apply something like WD40 (or better alternatives) to the valve after you've checked and see if it still happens the next day. If it's gone away, then you know the cause. If you have warranty still, then you'll be able to get the dealer to resolve (or supplier if it's an aftermarket product).
Thanks gents. Still have warranty and first service due, will get it sorted then
- RossDagley
- Top Gear
Likely passenger side back box heat shield. Known to rattle.
Previously:
Previously:
Yeah, that too and easier fix!
any fix?
To the heatsheild?
- RossDagley
- Top Gear
Heatshield just needs bending differently normally - mine was rattling against the underside of the boot floor.Brooner wrote:any fix?
Might be as simple as a stone between the heatshield and the body of the car. Had a few of those also.
Previously:
Previously:
thanks will check it out see if it is this
Mine do also it. Goes after minute or so and all ok after big rush of air on start up its on most audi
rs4 b8 Suzuka, grey 14
As I understand it, the start up rattle is pretty normal, it's to do the emission regs. My 2012 one does the same.
Depends what's rattling, surely?
I have no idea what it is, is booked in on the 27th, will let u guys know what they say mine was
Users browsing this forum: Thedarkside and 43 guests
