DRL look a bit yellow
PetrolDave
Re: DRL look a bit yellow
Post by PetrolDave » Sat Oct 10, 2015 11:42 am
borry wrote:I shelled out near £30 on some PIAA ones, I really hope it is a case of "you get what you pay for" because these should last me a long time (I'm hoping!)
I fitted the PIAA ones in 2007 and am on the second set now (you can only buy them in pairs so I swapped both) after one blew in 2012. On that basis I should be good until 2017...
borry
Post by borry » Sun Oct 11, 2015 9:25 am
PetrolDave wrote:I fitted the PIAA ones in 2007 and am on the second set now (you can only buy them in pairs so I swapped both) after one blew in 2012. On that basis I should be good until 2017...
Excellent! Sounds like they are the business. :thumbs:
marc1 wrote:Obligatory pictures Borry...
I'll get one up later today buddy. :beerchug:
borry
Post by borry » Sun Oct 11, 2015 5:25 pm
Here ya go fella!
Not the best pic but they are fine in terms of brightness, the CREE LED white ones I had on before looked better but if the f**kers keep blowing every couple of weeks they're no good at all.
Post by MikeFish » Sun Oct 11, 2015 7:53 pm
Here ya go fella!
I have had my Cree DRLs for a few weeks now with no issues so far.
TAB1S
Post by TAB1S » Thu Nov 05, 2015 9:04 pm
Trups wrote:Im working on a new setup to replace/update the current one that I supply but not due for a couple of months.
trups
Any news on these Trups im wanting quite a few bit from you but want to do it all at once obviously.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift :mrgreen:
Trups
Trader (Expired)
Post by Trups » Thu Nov 05, 2015 10:22 pm
Hi.
You able to wait a week and il have an ETA. Just testing the new drivers etc. The new bulb will be made from a cnc'd base and will replicate the OEM holder so no need to mess with the old type cancellers and be a few choices of brightnesses etc.
TAB1S
Post by TAB1S » Thu Nov 05, 2015 10:36 pm
Trups wrote:Hi.
Yes mate no worries, sounds great.
RS4 B7
Trups
Trader (Expired)
Post by Trups » Tue Nov 10, 2015 11:05 pm
TAB1S wrote:
Trups wrote:Hi.
Tested today in an 8p as have the same issue with drl's as the B7 but that can be coded and no canceller needed but not everyone has vcds.
I had 2 sets of circuits and one worked :) so that set has been posted to a member on the forum today to test in his rs4, if all is well then il be doing the final specs/design and get these produced.
Trups
Trups
Trader (Expired)
Post by Trups » Thu Nov 12, 2015 10:40 pm
Can confirm that the circuitry works on the rs4, tested by member Daytona for me.
Will have a full fitting and working proto type for the end of the month I hope and then once pictures etc have been done il take photos.
Trups
TAB1S
Post by TAB1S » Thu Nov 12, 2015 11:06 pm
Trups wrote:Can confirm that the circuitry works on the rs4, tested by member Daytona for me.
Trups
Brilliant thanks Trups, looking forward to it. :thumb:
RS4 B7
Trups
Trader (Expired)
Post by Trups » Wed Dec 30, 2015 8:07 pm
here is an update of what I been working on - viewtopic.php?f=93&t=118252
Post by MikeFish » Wed Dec 30, 2015 9:16 pm
Keen to see this. I have finally have a system with no bulb faults and with no resistors or mods. The only bit I have that would be nice to lose are the DRL cancellors so I am keen to find a solution where I don't need these.
Trups
Trader (Expired)
Post by Trups » Wed Dec 30, 2015 10:06 pm
You loose the canceller box on the new system Mike. As there will be a small one with the driver but all encased in a cnc'd box which is half the size of the previous solution.
Trups
Trader (Expired)
Post by Trups » Sat Aug 06, 2016 10:51 am
update on the New bulb - viewtopic.php?f=93&t=118252
Users browsing this forum: Google Adsense [Bot] and 99 guests
