Front Discs and pads - anyone renewed?
Re: Front Discs and pads - anyone renewed?
Might be checking in the RS5 forum to see if there have been any tests. I've stuck with the OEM each time, not really needed a reason to look elsewhere, other than all that dust!
It's all torque talk.
Went for my first service today at 14k miles (car 18 months old) and they said front brakes were 35% worn and rear are 30% worn. Think I must be driving like miss daisy compared to the OP here!
Current: 2017 RS6 Performance in Nardo Grey
Previous: 2014 RS4 in Sepang Blue; 2011 Q5 3.0TDi Sline Plus in Ibis White; 2007 Audi S5 4.2 V8 in Phantom Black; 2006 VW Golf GTi in Tornado Red; 1998 VW Golf 1.9 TDi in Navy Blue; 1988 VW Polo 1.0 in Gold
- Vodkaking77
My car is 18k miles and I am on my second set of front pads.
Just had my discs and pads replaced at 11k
Pads were 60% worn but the discs were warped due to excessive heat and manner of driver apparently! It is an RS, Would have expected them to handle a bit of spirited driving.
£1300 for both!
£1300 for both!
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
You've been done.....I was quoted £1150........however that was the lowest of three dealers I called......I had my front pads replaced yesterday at 16k miles...£432.....a rip off too but the cheapest dealer price I could find.Macdaddy wrote:£1300 for both!
- RossDagley
- Top Gear
Genuine discs are £626. Fitting is 10 minutes extra per side max if you're doing pads.
Genuine pads are £280. Fitting is 15-20 minutes max per side at home.
Screw paying someone £250 for an hours work (or worse £400). And that's presuming Audi pay TPS prices, which they dont...
Bring it to me - I'll only charge you £100 for the hour...
As for being warped due to the style of driving that's a bit of bullshit imo sorry. Mine are fine and get driven plenty hard. Trackdays, Nurburgring, more agressive pads etc.
Previously:
Previously:
Ross, whats the part number for the pads and where to buy mate?RossDagley wrote:Genuine discs are £626. Fitting is 10 minutes extra per side max if you're doing pads.
Bring it to me - I'll only charge you £100 for the hour...![]()
- RossDagley
- Top Gear
8E0698151Q Pads
8T0615301 Discs
Prices above from TPS mate but pads are on eBay for the same price (almost and seller takes offers):
http://www.ebay.co.uk/ulk/itm/261792410826
8T0615301 Discs
Previously:
Previously:
Thanks Ross!
As e'en said already the front pads are a dodel to replace but the rears are quite different now we have an electronic hand brake
I will have to use a dealer to replace the rear pads when the time comes
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
If you have VCDS it is pretty straightforward I believe (I've not done mine yet). Its just a case of using it to tell the calipers to open/close.Brooner wrote:As e'en said already the front pads are a dodel to replace but the rears are quite different now we have an electronic hand brake
My ex had an 07 plate A6 with and electronic hand brake. I didn't realise the different procedures required
- Graeme4130
Just for info, if anyone else has this coming up ;
I had the front pads on my car replaced this week for £510 inc fitting etc at my local dealer
They're ceramic, so I knew they'd be expensive, but I guessed they might last a bit longer than 28k miles
Saying that, they've probably had a fairly hard life
