Clutch temp warning - torque limited
3.0 V6 24v TFSI - 329 bhp
sebgreen
Post by sebgreen » Wed Aug 19, 2015 10:42 pm
This error has come up on my 2011 S4 DSG.
The car drives ok with it - the gearbox just changes gears at a lower rpm. After a reset at the garage it is back to normal. No doubt it will do it again. Mechanic says come back if/when it does and we can look at going down the new clutch route...
Anyone else had this problem or similar? Anyone know a solution that does not involve a clutch replacement?
Re: Clutch temp warning - torque limited
Post by Ian_C » Wed Aug 19, 2015 11:25 pm
sebgreen wrote:Anyone else had this problem or similar? Anyone know a solution that does not involve a clutch replacement?
Buy a new S4
Probably not the answer you were hoping for sorry, but there cannot be any other solution than new clutch packs, surely?
sebgreen
Post by sebgreen » Thu Aug 20, 2015 6:38 am
Ian_C wrote: Probably not the answer you were hoping for sorry, but there cannot be any other solution than new clutch packs, surely?
If that is the solution then it will have to be that - I was just wondering if there was any way to adjust the clutches via software or anything.
sebgreen
Post by sebgreen » Fri Aug 28, 2015 8:17 am
Thanks for that - so it does appear that the clutch can be adjusted via software.
Skiptowncat
Post by Skiptowncat » Fri Aug 28, 2015 9:02 am
I reset mine and it worked flawlessly for a while, the hard 1-2 shift has stare to return now though.
sebgreen
Post by sebgreen » Mon Aug 31, 2015 12:02 am
I felt the clutch slip today. Think it is time to investigate a new set
sebgreen
Post by sebgreen » Sat Sep 19, 2015 10:08 am
Car is at the local specialist getting fixed, I hope
xxx_mojo_xxx
Post by xxx_mojo_xxx » Sat Sep 19, 2015 3:08 pm
I thought the DSG unit was a sealed no serviceable component apart from the oil?
sebgreen
Post by sebgreen » Sun Oct 04, 2015 9:04 am
xxx_mojo_xxx wrote:I thought the DSG unit was a sealed no serviceable component apart from the oil?
It is a gearbox. Audi have a habit of saying "replace the unit" when something goes wrong. Now they will repair it as a few specialist companies offer it so they were loosing business. It is not sealed. Just complicated.
Car had the mechetronics upgrade/repair kit done. Only got it back on Friday. Hopefully all sorted.
Post by Ian_C » Sun Oct 04, 2015 4:21 pm
Fingers crossed!
GrahamS4
Post by GrahamS4 » Sun Oct 04, 2015 5:42 pm
What companies are offering repair?
sebgreen
Post by sebgreen » Sun Oct 04, 2015 5:43 pm
Well it obv depends on the problem. I haven't really tested mine enough to to say 100% solved.
I used a company call VAG Bolton in Manchester.
xxx_mojo_xxx
Post by xxx_mojo_xxx » Sun Oct 04, 2015 8:53 pm
sebgreen wrote:
GrahamS4 wrote:
sebgreen wrote: It is a gearbox. Audi have a habit of saying "replace the unit" when something goes wrong. Now they will repair it as a few specialist companies offer it so they were loosing business. It is not sealed. Just complicated.
I was under the impression that VAG never supplied the mechatronic unit separately to consumers, and it was only available to dealerships for warranty work to keep repair costs down.
I guess the situation has changed?
sebgreen
Post by sebgreen » Sun Oct 04, 2015 10:33 pm
xxx_mojo_xxx wrote:
sebgreen wrote:
GrahamS4 wrote: What companies are offering repair?
The place I went to are approved by Audi, if that is even possible. Use all the same systems. Get access to all the updates - could see my car needed a gearbox software update and did it at the same time.
Showed me the systems they use and looked identical to the ones I have seen being yes at Audi.
Users browsing this forum: No registered users and 55 guests
