DRL look a bit yellow
Hi guys
My drl bulbs are standard and look a bit yellow
Can u buy any led bulbs off eBay to give it a bit of Xenon effect?
Re: DRL look a bit yellow
Yes but I've not found any yet that don't give a dash warning. I now have a set of warning cancellers from Trups.
Were they from eBay?
A link would be grate
Was worried about error messages
Not from eBay. Had a few eBay bulbs in the past fitted to different cars and they tend to flicker or not last. These bulbs have a 2 or 3 year warranty I think and had good reviews.
http://www.autobulbsdirect.co.uk/382-ul ... -bulb.html
Cheers they look spot on
- PetrolDave
Worth looking at the PIAA Xtreme White bulbs, they are a much closer match to the Xenon headlights and as they're not LEDs don't cause bulb warning problems.
Im working on a new setup to replace/update the current one that I supply but not due for a couple of months.
trups
trups
To alleviate dash errors, like Mike mentions, you need Trups' cancellers.
Used with Trup's DRL canceller, I used these CREE LED DRL's. A bit more expensive, but I can testify they are bright:
http://www.ebay.co.uk/itm/P21W-BA15s-50 ... 35c91463ca
Gone but never forgotten:
Mine work, no errors.
Not with the CREE versions - you need the cancellers...marc1 wrote:Mine work, no errors.
http://www.ebay.co.uk/itm/2-x-P21W-1156 ... 3a97f0fcee
I installed these with no issues whatsoever, no dash warning lights nothing.
Similar kit to mine, you get the cancellers that clear the errors, did you have to trim any lugs as I do when the cancellers come in or they wont fit flush.Covkiller wrote:http://www.ebay.co.uk/itm/2-x-P21W-1156 ... 3a97f0fcee
Nope not CREE ones. The ones I posted the link to from auto bulbs direct. £29.99 and 2 or 3 years warranty, seemed a good option as can be returned if there are any problems. They are massive though i.e. Only just fit through the hole. I assume they are that big as house whatever sort of cancelling device inside the bulb. To be honest though, as per Dave's post the PIAA bulbs seem to get good reviews.neilparf wrote:Not with the CREE versions - you need the cancellers...marc1 wrote:Mine work, no errors.
No mods nothing. They fit the oem housing well.Trups wrote:Similar kit to mine, you get the cancellers that clear the errors, did you have to trim any lugs as I do when the cancellers come in or they wont fit flush.Covkiller wrote:http://www.ebay.co.uk/itm/2-x-P21W-1156 ... 3a97f0fcee
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 98 guests
