heavy smoke on first start
5.0 V10 50v biturbo - 571 bhp
tony091
Post by tony091 » Sat Aug 15, 2015 7:26 am
hi there
has anyone had a problem with heavy smoke on first start , been checked out lots of times and whenever it goes to the garage it never does it lol, its very intermittently can be fine for 7-10 days then 1 morning bang smokes heavy for 2 mins when cleared all fine ? been told possible turbo seals worn or some sort of valve not working , head gasket is fine and valve stem seals fine , don't lose water or oil ?? just this embarrassing smoke lol.
Ungjaevel
Re: heavy smoke on first start
Post by Ungjaevel » Sat Aug 15, 2015 7:38 am
Have you been doing anything in particular before parking your car, and having problem?
Id place my bet on turbo seals as well.
classba
Post by classba » Sat Aug 15, 2015 9:08 am
What colour is the smoke and were you reving the car at cold start?.
BTW... FON
MNK
Post by MNK » Sat Aug 15, 2015 9:37 pm
When cold these things are like a smoke machine. White smoke, then once the idle revs drop after 1-2 mins it should go away.
tony091
Post by tony091 » Sun Aug 16, 2015 7:30 am
cheers for all your replies, yes its strange hasn,t done it in days then yesterday , wollop massive amount of smoke gone after driving for a few minutes then good all day , the smoke itself smells a little oily & carbon but more like a vapour as its more white in colour and don't smell ignited , I have heard of oil vapour hoses and turbo seals letting oil past straight into the exhaust manifold , I think its the route to go down .
regards tony
marc1
Post by marc1 » Sun Aug 16, 2015 8:22 am
Get a video up mate, it will be much easier to diagnose. Or a picture at least.
tony091
Post by tony091 » Thu Aug 27, 2015 2:56 pm
hi again
smoking seems to be getting worse does anyone know of a descent RS specialist garage in the Essex/London area that might be able to sort out this problem ? regards
IanH755
Post by IanH755 » Thu Aug 27, 2015 3:06 pm
AMD are down by the Dartford Tunnel in Essex should you want to pop in.
tony091
Post by tony091 » Thu Aug 27, 2015 3:14 pm
cheers ian
clark001
Post by clark001 » Sat Aug 29, 2015 5:17 am
Hi!
is your car 2008 or early 2009?
in this time audi made a bad oil return pipe and they use upgraded one in 2009-2010
the new one have a little "tank" for the oil.
if u have the old one it can made the smoke....
best regards
Golfather
Post by Golfather » Sat Aug 29, 2015 12:19 pm
^^^ This.
But only affects the right exhaust.
There is a recall available and should be done under warranty - check with your dealer.
Ricky.REP
Post by Ricky.REP » Mon Aug 31, 2015 2:33 pm
Get someone else to start the car after a few days, is it definitely white smoke?
If so, that water/steam.....are you losing coolant?
If it has a tinge of blue then it could be valve stem seals, oil in the inlet tract or weeping turbo bearings.
I hope this helps.
Cheers Ricky
tony091
Post by tony091 » Mon Sep 07, 2015 6:18 pm
thanks for all your replies
its now in a rs specialist and they are on the case now ? will keep all updated ,
Fatneck73
Post by Fatneck73 » Mon Sep 07, 2015 7:03 pm
What specialists did you take it too?
Smudger51
Post by Smudger51 » Fri Sep 11, 2015 11:14 am
I have exactly the same issue. Got the turbo's serviced, as there was oil in the intercoolers. Sadly, although this sorted the turbo's, I still have the smoking problem.
Booked into MRC at the end of September to see what they can find......
Users browsing this forum: No registered users and 36 guests
