Front brake pads recommendations please
Re: Front brake pads recommendations please
IIRC, there are only 4 pads in that set so you would need two sets.
Much cheaper at Camskill anyway:
http://www.camskill.co.uk/m49b0s4048p53 ... Brake_pads
I'm pretty sure that Audi supply Pagid, but not the usual ones. I think they are from the Pagid "RS" range (or something like that.sulli wrote:GSF do Brembo, is this not what Audi supply?
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
Do ate do pads that fit?
Yup. They will all be much the same unless you get performance pads. I.e. Will stop the car but not tolerate any serious abuse (or driving, as I call it).
yes ATE pads at ECP £120.tmg wrote:Do ate do pads that fit?
Stoke Audi £305, TPS for same £270. Camskill do DS2500s for £280.
Daytona RS6 saloon, KW v3s, Hotchkiss ARBs, Milltech non res, MRC
CI Granduca Motorhome!
Has anyone used EBC red, yellow or blue stuff on the Rs6?
Most people slate them.
Looks like ds2500s then, better deal than OE! Better pads too, have used them in other cars and they are awesome...
Used DS2500 in mine, fantastic pad!
DS2500s arrive so after a hitch of a week at work I decided to do something positive instead of resorting to beer, and make a start at 6pm, should be done by 7....
Fuckin fuckety <beep> <beep> it was!
Old pads won't come out without removing calipers, so I set about that, no big deal right? Well on my drive it is when calipers bolts are seized. After an hour, a broken thumb, an ASBO for my fruity language my neighbour gets home and wheels out his massive trolley jack to get some more height and a breaker bar,which does the trick. Until I get to the pad sensor, well the DS2500s don't have one. So just remove existing? Nope can't disconnect it... However doesn't seem to trip the warning light as is so will just tie it out of way. So 3 hours and darkness scuppered me, the other side in the morning. Why oh why do simple jobs always go thus?
Just wait until you have to do something more serious. Epic cars, but a bitch to work on with everything packed in so tight.
+10000
I need a set of rears - looking at the links above for the DS2500s, it quotes 120 quid.
Price from Audi inc VAT - under 90 quid.
Seems a no-brainer? Or am I missing something?
I have always used cheap Brembo pads on the rear. I've had the fronts on fire and boiled the fluid, but I've never come close to getting the rears to work up a sweat.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 65 guests
