01331 - Door control module driver side
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
wardy124
Post by wardy124 » Thu Aug 13, 2015 6:29 pm
I had my alternator changed last week and have had an intermittent problem with the drivers window.
This morning when I got in the car I noticed the DIS did not show the door open like normal.
When I arrived at work and closed the windows, I could not open them again.
Ive run a diagnostic and its showing the error in the title.
Where is the door control module? Could something have been disconnected or disturbed when changing the alternator?
The problem I have now is there is no power to the drivers door, I can't even lock the car?
Any help would be greatly appreciated!!
Wardy
C6 S6 completely standard car just imported with full history from Switzerland - Needs an exhaust!!
B6 S4 Misano Red, KW V3's, RS4 ARB's, Miltek
Surrey Sam
Re: 01331 - Door control module driver side
Post by Surrey Sam » Fri Aug 14, 2015 8:37 am
Does the door speaker work?
wardy124
Post by wardy124 » Wed Aug 19, 2015 10:57 am
Hi Sam,
I found the issue, it was in no wy related to the alternator change last month....
I opened the rubber boot that covers the door to body part of the loom and found the 2.6mm brown wire had broken..
I guess this is the power for the door control module? Last night I spliced the wire back together and the problem is solved!
The 01331 error was a "no communication" error I guess?!
Paul
Surrey Sam
Post by Surrey Sam » Wed Aug 19, 2015 6:50 pm
Good work Paul, that was where my question was leading to but you've found it out anyway. :thumbs:
Return to “DTC / VCDS”
