How-to guide. Fix your leaking / deflating bolsters!!
lugars4
Post by lugars4 » Sun Aug 09, 2015 5:22 pm
The leaking side bolsters on my B7 RS4 have been annoying me for years.
It was fixed under warranty 3 years ago, but after a year it was leaking again.
Today i decided to tackle it. It wasn't as hard as i feared to get to the valves and i was pleased to find the problem and cure it for a few quid!! Much better than spending £160 per valve !!
First remove the recaro seatbelt loops, item 10 in the image. They are retained by tabs on item 8. I did it from the back seat of the car, gently levering item 10 up and away from item 8. Its common to break the tabs on item 8 doing this, as Audi did when they replaced my valves some years ago!!
So i am purchasing new item 8's.
Next, release the leather. It pulls out of the retaining grooved in the backrest as shown.
Releasing the leather all the way around the backrest, the seat cover can pivot forward. (I left the leather attached at the base).
The lumbar pad is removed in this image, exposing the valves. The left valve (Item 7) controls the side bolsters. The right valve (also item 7) controls the Lumbar.
To remove the valve, disconnect the connector and carefully pull the hoses off, noting their locations for re-fitting!
After hours of investigation and leak tracing, i found this crack. (Circled red). (Don't remove the brass insert, it is not necessary.)
The crack is most likely caused by the the brass insert being too large and splitting the plastic housing open over time.
To fix, fill the cavity behind the crack and around the base of the brass insert with a 2-part Araldite or a similar hard setting glue. (in this pic i have the valve apart, this is not necessary)
What i found interesting is that i had one leaking valve and one good. The leaking valve is stamped 2005 manufacture. The good valve is 2009. Maybe they improved it?
When i re-assembled it, i noticed the lumbar pad plastic retaining screws that go into the white foam had worm the hole in the foam out, allowing the lumbar pad to slip down.
I re-filled the holes with expanding foam, should give it a few more years life.
Hope this helps someone.
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
Seattle-squash
Re: How-to guide. Fix your leaking / deflating bolsters!!
Post by Seattle-squash » Sun Aug 09, 2015 6:59 pm
Impressive!!!
Surrey Sam
Post by Surrey Sam » Sun Aug 09, 2015 9:21 pm
Nice write up and investigation :thumbs:
I did this a couple of weeks back, although I replaced the faulty solenoid with a new one - I've still got the old one in the bottom of the toolbox, so will have to pull it apart and check out the component failure. The last person to document in that sort of depth mentioned it was the rubber seal in their opinion, so will be interesting to find out (thread link below).
viewtopic.php?f=35&t=96867
For a skinny runt like myself who needs them at maximum inflation, it's nice to get them holding pressure again.
Rick_RS4
Post by Rick_RS4 » Sun Aug 09, 2015 9:27 pm
awesome thanks for the writeup,
not sure if my pump has gone as i dont hear it when i press S anymore
Post by MikeFish » Sun Aug 09, 2015 10:07 pm
Nice guide. I remember reading that old thread that said it wasn't repairable so never bothered.
It is probably worth adding that each seat has 2 valves; one valve does the thigh and upper side supports, the other one does the lumber support so worth checking if both valves has gone before attempting repairs.
lugars4
Post by lugars4 » Sun Aug 09, 2015 10:08 pm
Surrey Sam wrote:Nice write up and investigation :thumbs:
I also thought it was the rubber seat, the crack only showed up with leak detector.
If it is the same on your old valve, you might have a working spare after some araldite :)
Let us know if it is...
slowcoach
Post by slowcoach » Tue Aug 11, 2015 10:31 am
Did this fix to mine yesterday ,worked perfectly :notworthy:
Audi RS4 B7 Saloon - Avus - SS+ Suspension - Tubi Exhausts (once i get round to fitting them...)
neilparf
Post by neilparf » Tue Aug 11, 2015 10:52 am
Mine are still going strong, but I suspect in time I'll be doing this - great write up ;)
Gone but never forgotten:
lugars4
Post by lugars4 » Wed Aug 12, 2015 12:17 pm
slowcoach wrote:Did this fix to mine yesterday ,worked perfectly :notworthy:
Nice one, glad it's working for other people. Was the crack in the same position?
slowcoach
Post by slowcoach » Wed Aug 12, 2015 3:31 pm
I didn't remove the brass couplers to find out i just sealed round them all
lugars4
Post by lugars4 » Wed Aug 12, 2015 5:41 pm
Ok no worries.
I could see the crack with the brass insert still fitted. Just have to look really closely.
Glad its working out for you.
BaCoN
Post by BaCoN » Thu Aug 13, 2015 12:09 am
Awesome write up, I will be attempting this on the weekend along with a bumper alignment! Thanks!!
Dolphie
Post by Dolphie » Sat Aug 15, 2015 4:38 pm
lugars4, I can be a bit hamfisted at times. I think I'm worried about making a dog's dinner when removing the seatbelt loops. How difficult is it? What did you use to prise them off?
Roughly how long did the job take. If I have a disaster I can't afford the car to be off the road as it's my daily.
Cheers.
Rick_RS4
Post by Rick_RS4 » Sun Aug 16, 2015 12:36 am
Dolphie wrote:lugars4, I can be a bit hamfisted at times. I think I'm worried about making a dog's dinner when removing the seatbelt loops. How difficult is it? What did you use to prise them off?
Cheers.
put 2 fingers in under the loop and push up then pull out :biggrin3:
BaCoN
Post by BaCoN » Sun Aug 16, 2015 12:59 am
I used 2 thin plastic paint scrapers and put one in the top and one in the bottom and it popped off pretty easy.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 192 guests
