Front brake pads recommendations please
Re: Front brake pads recommendations please
Post by Shoppinit » Wed Jul 01, 2015 8:22 am
IIRC, there are only 4 pads in that set so you would need two sets.
Much cheaper at Camskill anyway:
http://www.camskill.co.uk/m49b0s4048p53 ... Brake_pads
Rstoney
Post by Rstoney » Wed Jul 01, 2015 12:18 pm
Even cheaper here:
http://www.bestbrakepads.co.uk/search_r ... rds=Rs6+c5
Free postage too!
seaneb
Post by seaneb » Wed Jul 01, 2015 1:05 pm
sulli wrote:GSF do Brembo, is this not what Audi supply?
I'm pretty sure that Audi supply Pagid, but not the usual ones. I think they are from the Pagid "RS" range (or something like that.
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
tmg
Post by tmg » Wed Jul 01, 2015 8:14 pm
Do ate do pads that fit?
Post by Shoppinit » Wed Jul 01, 2015 10:59 pm
Yup. They will all be much the same unless you get performance pads. I.e. Will stop the car but not tolerate any serious abuse (or driving, as I call it).
sulli
Post by sulli » Fri Jul 10, 2015 8:00 am
tmg wrote:Do ate do pads that fit?
yes ATE pads at ECP £120.
Stoke Audi £305, TPS for same £270. Camskill do DS2500s for £280.
Daytona RS6 saloon, KW v3s, Hotchkiss ARBs, Milltech non res, MRC
CI Granduca Motorhome!
sulli
Post by sulli » Fri Jul 10, 2015 9:05 pm
Has anyone used EBC red, yellow or blue stuff on the Rs6?
Post by Shoppinit » Fri Jul 10, 2015 10:11 pm
Most people slate them.
sulli
Post by sulli » Fri Jul 10, 2015 10:14 pm
Looks like ds2500s then, better deal than OE! Better pads too, have used them in other cars and they are awesome...
IanH755
Post by IanH755 » Sat Jul 11, 2015 11:52 am
Used DS2500 in mine, fantastic pad!
sulli
Post by sulli » Sat Aug 22, 2015 1:37 am
DS2500s arrive so after a hitch of a week at work I decided to do something positive instead of resorting to beer, and make a start at 6pm, should be done by 7....
Fuckin fuckety <beep> <beep> it was!
Old pads won't come out without removing calipers, so I set about that, no big deal right? Well on my drive it is when calipers bolts are seized. After an hour, a broken thumb, an ASBO for my fruity language my neighbour gets home and wheels out his massive trolley jack to get some more height and a breaker bar,which does the trick. Until I get to the pad sensor, well the DS2500s don't have one. So just remove existing? Nope can't disconnect it... However doesn't seem to trip the warning light as is so will just tie it out of way. So 3 hours and darkness scuppered me, the other side in the morning. Why oh why do simple jobs always go thus?
Mɐʇʇ
Post by Mɐʇʇ » Sat Aug 22, 2015 11:17 am
Just wait until you have to do something more serious. Epic cars, but a bitch to work on with everything packed in so tight.
Post by Shoppinit » Sat Aug 22, 2015 11:54 am
+10000
Mɐʇʇ
Post by Mɐʇʇ » Mon Aug 24, 2015 9:18 am
I need a set of rears - looking at the links above for the DS2500s, it quotes 120 quid.
Price from Audi inc VAT - under 90 quid.
Seems a no-brainer? Or am I missing something?
Post by Shoppinit » Mon Aug 24, 2015 10:19 am
I have always used cheap Brembo pads on the rear. I've had the fronts on fire and boiled the fluid, but I've never come close to getting the rears to work up a sweat.
