S4 Alternator
wardy124
S4 Alternator
Post by wardy124 » Wed Jul 08, 2015 6:24 pm
Evening all,
I was on my way to my lock up this evening and heard a noise like a flat tyre but without any loss of control of the car.
The battery light came on and I figured it must be the alternator belt flapping around, the lock up was 500m away so I made it there and got underneath.
I have no idea how this had happened but the pulley and shaft are flapping around a fair amount so it's new alternator time....
Can anyone recommend a place to get hold of a recon or decent second hand unit as the new part from Audi here is over 1k Euro and right now I just don't have the cash....
Any help would be amazing!
Wardy
C6 S6 completely standard car just imported with full history from Switzerland - Needs an exhaust!!
B6 S4 Misano Red, KW V3's, RS4 ARB's, Miltek
SuprSi
Re: S4 Alternator
Post by SuprSi » Wed Jul 08, 2015 6:51 pm
Hi Wards,
Hmm, bearings must have failed.
Maybe you could get a used part from a breakers? Check the part number and you'll probably find its the same alternator as an A4.
wardy124
Re: S4 Alternator
Post by wardy124 » Fri Jul 10, 2015 11:23 am
Hi SuprSi,
Thanks for the help,
Unfortunately the Delphi alternator on the S4 is water cooled... I have never seen anything like that before!!
I managed to find a second hand unit From germany with a years warranty on it for under 400€ delivered vs 1075€ + tax from Audi!
It's not quite such a shock now!
marc1
Re: S4 Alternator
Post by marc1 » Fri Jul 10, 2015 11:49 am
S4 alternatators are water cooled due to the heat build up in the engine bay with the big 4.2 lump in there. I recall the Bosch item was superseded by a hitachi unit, but the cooling was routed differently and therefore you need additional pipe work, etc. It's a fairly pricey item if I recall.
SuprSi
Re: S4 Alternator
Post by SuprSi » Fri Jul 10, 2015 11:53 am
They must get bloody hot if it's beneficial to 'cool' them with 100C+ water!
I think the rs4 is water cooled too, probably where it's at the back of the engine. Mines at the front and only air cooled.
marc1
Re: S4 Alternator
Post by marc1 » Fri Jul 10, 2015 4:04 pm
Maybe so Si. I don't recall seeing change from £2k on a previous S4 way back when. :audibash:
wardy124
Re: S4 Alternator
Post by wardy124 » Thu Aug 13, 2015 10:11 am
Good news and bad news here....
I sourced an alternator from Germany, had it installed no problem, changed the belt and tensioners at the same time.
Following the battery being disconnected the drivers window would not one touch close, I followed the instructions in the manual, holding the button for 1 second in the up position, problem solved. Every time the car was locked the problem returned....
I did notice that sometimes the door open indication on the DIS would flicker on and off as the door opened and today, nothing from the drivers door at all!
No lock function, the interior light stays on when the door is closed, no window operation for the whole car?!!
Is there a cable that could have been disconnected or nipped during the alternator installation?
I noticed that they had the wheel well liners out when they were working on it?
Any help would be great!
Wardy
