Inlet manifold flap sensor
Afternoon chaps.
Currently cars struggling a bit. Car struggles to go at around 3000rpm. The manifold flap position sensor is not functioning. Im getting a fault code of P2014, lower limit reached. Or code 08212. Ive already changed the vacuum solenoid which controls the flaps.
Is the part number I require 03C907386D. Is the part number the correct one?
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
Re: Inlet manifold flap sensor
Sorry forgot to mention, that I have tried adaption for the position sensor but am getting an error each time. So it must be caput.
- orangepeel
- 1st Gear
Bank 1 or 2
Its bank 1. I take it, that both banks dont have the same sensor part number.
just call audi parts or tps and tell them what you want, they are pretty clued up
ETKA lists it as the correct part number but with the suffix B. I suspect it's been superceded by the D suffix however. And they are both the same on bank 1 and 2.
Thanks for the replies, I spoke to Audi today and the suffix D, superceded the B.
I had same issue, mine unfortunately has w worn bushing/linkage, so I pulled the flaps, left original sensors, and added coding out "flap sensors" options with the JHM tune. Was not worth cost of new manifold/bushings.
Mine was bank 2 hence intake had to come off anyways.
If I do go down the de-flapping route, would I need a kit. I will need a tune, thats a given. Im assuming the breather pipes will have to be re-routed.
If you just need the sensor I have a spare you can have. If it's bank 1 as you say it's changeable with the manifold still in place. It's a bugger of a job but it is doable. PM me if you want it.
Have you done a test on the vac system with VCDS to confirm that the flap arms are actually moving ?
Users browsing this forum: No registered users and 70 guests
