20" Wheels but keeping with Original Style
anawaz
Re: 20" Wheels but keeping with Original Style
Post by anawaz » Sat Jun 20, 2015 4:02 am
ChrisW wrote:I need lows like that ^
makes two of us !
the right choice for those looking to keep the original look.
your car with those wheels looks stunning my friend, end of !!
dillonc
Post by dillonc » Sat Jun 20, 2015 5:09 am
Here's mine with 255/30/20. Factory option for B8 S5.
Wheel spec is 20x9" et 29 with 66.6 centre bore.
Covkiller
Post by Covkiller » Sat Jun 20, 2015 12:33 pm
anawaz & ChrisW
:thumbs:
anawaz
Post by anawaz » Sat Jun 20, 2015 3:15 pm
TAB1S wrote:I have this set up also & imo its the best! also lowered on kw v3's with 265/35's, 10mm rear & 8mm front spacers with no rubbing.
Hey TAB1S
I've come across another set, this time being offered ET29ers with 265/30/20 boots. My suspension setup is standard as far as i know.
numpty question, but from your experience what needs to be done for me to mount these in terms of offset spacers/spigots?
cheers
Post by MikeFish » Sat Jun 20, 2015 8:50 pm
With 265 tyres I'd be careful with spacers as you could get rubbing. I believe people have run 265 or 275 before with no rubbing but it could be close.
You will need spigots if the centre bore of the new wheels is 66.6. If the centre bore is 57.1 you won't need them.
TAB1S
Post by TAB1S » Sat Jun 20, 2015 9:22 pm
Hey TAB1S
cheers
As MikeFish said bud just spigots.
i have no rubbing at all, iv even had my old set of 19's in the boot with tyres to deliver to there new owner!
All i have done is remove the small screw from the front arch liners top centre folling advice from these guys.
im not 100% but i would imagine that my set up would be slightly harder than the original set up as im on MRC fast road but mines also lower so your OEM set up should be fine.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift :mrgreen:
anawaz
Post by anawaz » Tue Jun 30, 2015 1:20 pm
ok so wheels turned up, but tyres are all over the Shop - typical :-/
i've costco account, they seem to be on the money most times, but any other places where to look.
265/30/20's x4 required.
FaisalJ
Post by FaisalJ » Tue Jun 30, 2015 2:48 pm
anawaz wrote:ok so wheels turned up, but tyres are all over the shop - typical :-/
www.tyreleader.co.uk
www.mytyres.co.uk
www.camskill.co.uk
I've used all of the above at various points without any issues. Most recently I bought from ebay seller "tyrespecialists".
http://stores.ebay.co.uk/tyrespecialists/
2007 RS4 B7 Avant
Post by MikeFish » Tue Jun 30, 2015 7:02 pm
Yep tyreleader are hard to beat on price. Think I got 4 eagle f1s in the size you want for about £780.
anawaz
Post by anawaz » Wed Jul 01, 2015 11:49 am
Tyreleader:
Dunlop Maxx GT - 169ea
Conti Cont3s - 182ea
Not much in it, but wanted to ask is one better than the other given they're so close in terms of price?
Rick_RS4
Post by Rick_RS4 » Wed Jul 01, 2015 1:51 pm
You want 255 30 20 to be the same radius as standard or 245 30 20
anawaz
Post by anawaz » Wed Jul 01, 2015 2:46 pm
255 ??
oh sh*t. the guys on this thread have been talking 265 only.
you have me worried :audibash:
Post by MikeFish » Wed Jul 01, 2015 6:41 pm
anawaz wrote:255 ??
I went over the size options in post 5 I think. I said 255/30/20 is the one you want.
I did mention in my last post that I bought some the same size as you for £780 but I meant 255s not 265. I did run a set of 265 without problems but there is obviously less clearance due to the extra width and height. In fact I think the extra size makes the speedo more accurate.
FaisalJ
Post by FaisalJ » Wed Jul 01, 2015 9:08 pm
The 265 also seems to be a less common and more expensive size. At least that's what I found when I was (briefly) considering 20's.
I'd go with Mike's advice; 255/30/20 GY eagle F1's
2007 RS4 B7 Avant
anawaz
Post by anawaz » Wed Jul 01, 2015 9:11 pm
So what we saying here then. is there agreement on 255 30 20 ??
remember i have standard suspension setup so is there still potential issue going with 265s ...
Users browsing this forum: No registered users and 104 guests
