Unlocking door with key
Drummerman
Post by Drummerman » Wed Jun 17, 2015 9:54 am
Hi guys, finally fixed a problem I have had with the car since I bought it. The DIS would never show that the driver's door was open. After changing the door lock and trying a second hand CCM, it turned out to be one of cable crimps in the loom by side of the driver's seat. So that fixed, my question is that when I unlock the driver's door with the key, it only unlocks the driver's door. Is this normal? Or have I got another wiring fault? Thanks
Nobby
Re: Unlocking door with key
Post by Nobby » Wed Jun 17, 2015 11:14 am
Pretty sure mine unlocks all. Also it doesn't disarm the alarm until you put the key into the ignition.
Daytona RS6 Avant
Nobby
Post by Nobby » Wed Jun 17, 2015 11:18 am
Actually thinking about it there are quite a few settings you can change and there is one called Selective Door Locking which only locks one door. Might be the same for unlocking. ]
You will need VCDS to check it though.
Daytona RS6 Avant
HPsauce
Post by HPsauce » Wed Jun 17, 2015 11:59 am
Drummerman wrote:when I unlock the driver's door with the key, it only unlocks the driver's door. Is this normal?
Normal I'd say, that's exactly what my S8 does and the remote unlocks all the doors. Didn't used to, I changed it with VCDS.
davethedesigner
Post by davethedesigner » Thu Jun 18, 2015 10:57 pm
I've just had to use the key for a week or so on my 6 and it was the same. Key only unlocks drivers door and you have to put the key in the ignition to disarm the alarm. Other doors would only open using the button on the drivers door.
All fixed now though (thanks again Carl)
Currently RS6 C5, VR6 Corrado, 1275 Mini, 100 2.6 Avant, Honda CBR600FY
Previously S4 B5
Users browsing this forum: srichards, steve2003rs6 and 75 guests
