What's the correct wheel alignment spec for the RS4 ?
CaptainLeadFoot
Post by CaptainLeadFoot » Mon Jun 08, 2015 4:23 pm
There are a lot of references for B5 and B8 but nothing for B7 :(
I had one done at the stealer today and said my toe angle was way off so they have to reset my subframe...the final results looks similar to a B5 but they gsave me a B8 spec on my alignment data sheet... :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash:
My current specs are:
FRONT
Toe L/R: 0°10'/0°10
Total 0°20
camber L/R: -1°06/-1°11'
caster: 4°00'/4°16
REAR
Toe L/R: 0°10'/0°09'
Total 0°20'
camber L/R: 1°20'/1°22'
thrust angle 0°00'
Does this sound ok ??
The_Coat
Re: What's the correct wheel alignment spec for the RS4 ?
Post by The_Coat » Mon Jun 08, 2015 5:12 pm
Had mine put on a Hunter machine the other week, everything was all in order so nothing needed changing. Not sure if this photo will help you or not:
RS4 Avant - Misano Red
CaptainLeadFoot
Post by CaptainLeadFoot » Mon Jun 08, 2015 5:19 pm
Thanks ! I think we have similar specs (your camber is even more sporty ! :D ) so all looking good ! :beerchug: :beerchug: :beerchug:
seaney76
Post by seaney76 » Mon Jun 08, 2015 7:39 pm
where has the hunter machine
The_Coat
Post by The_Coat » Mon Jun 08, 2015 7:42 pm
seaney76 wrote:where has the hunter machine
http://www.alignmycar.co.uk should be able to find one local to you.
Post by MikeFish » Mon Jun 08, 2015 7:59 pm
The_Coat wrote:Had mine put on a Hunter machine the other week, everything was all in order so nothing needed changing. Not sure if this photo will help you or not:
The small numbers in the corner of each section tell you the ideal range.
The_Coat
Post by The_Coat » Mon Jun 08, 2015 8:18 pm
Thanks for the info Mike, makes sense now.
Not really looked at the paperwork since I got it done, had the alloys re-done and new rubber so thought this would be handy to have. Only £6 as nothing needed doing.
neilparf
Post by neilparf » Wed Jun 10, 2015 1:49 pm
I let the Hunter system pull the base settings for 2ME sports suspension - it seems just fine to me...
Gone but never forgotten:
seaney76
Post by seaney76 » Sat Jun 13, 2015 8:15 pm
I've had four new goodyear eagle F1 tyres fitted, <beep> at kwik fit is telling me he can't do the alignment due to the suspension being uprated lowered ones!!! is this gobshite talking wet
Noyjatat
Post by Noyjatat » Sat Jun 13, 2015 9:36 pm
I believe if you have lowering springs or something similar on then you will also need front adjustable arms fitted too or you won't be able to achieve the right setup as the standard setup doesn't have the available adjustment. I am sure someone one here will have a more comprehensive idea and be able to explain it better.
frogracing
Post by frogracing » Fri Jun 06, 2025 5:46 pm
Reviving this thread as it popped up in my search for alignment, you can only adjust toe front and rear from the factory.
You will need adjustable upper arms (you can find them for front and rear) to adjust camber.
Here is a quick video showing the stock alignment procedure:
