rs6 / cylinder 1 stripped !!!
seb de la run
hi every one, since 6 month i have a problem with my rs6 , audi find the problem ; cylinder 1 is stripped.
what is the causes?
the milage is 20 000km.
so i must to change motor, and audi don t want to have a guarantee because i buy a used rs6 with a remap!!!!!!!
so someone have address to buy :
bloc
pisotns
cylinder head
or used or new engine
thanks you
what is the causes?
bloc
pisotns
cylinder head
thanks you
Re: rs6 cylinder 1 strippeg !!!
Get your self over to the "remap" thread.....Audi will repair FOC according to info on there?.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: rs6 / cylinder 1 stripped !!!
All of those parts are sitting on a car in a scrappie's in Poland currently. They also have a driver's door in sepang but no matching passenger door.
Dunno, not sure I'd fancy the engine out of that!
Sorry to hear this....that's just shows you these rs6's aren't indestructible. Hope you get sorted. Who did the tune?
Sometimes when u get greedy it bites you in the @rse
What do you mean by cylinder 1 is stripped? Why would you need a new block, pistons and cylinder head?
Has the piston broken, has the connecting rod come through the block, has the pistons caused head/valve damage?
I know English is not your first language but I would be interested to know what has gone wrong? Any pictures would be great?
Reading your previous posts, it looks like you bought the car in December and have had issues with it since, you have had an on-going issues with Cylinder 1 misfires by the look of things?
Also, I am unsure if your car is running modified ecu software (remap) or a piggyback/tuning box that is fooling sensors to extract more performance?
What's the quality of fuel like on reunion island? Octane rating? Due to your location, a fix is likely to be very expensive, we have reliable engine tuners and builders here in the UK that would no doubt be able to tune and rebuild your engine but that's no help to you when you live on a tiny island in the middle of the Indian ocean.
Have Audi actually denied a warranty claim on the car, if so, why? Did it flag with a TD1 warranty code due to modified software and you have it in writing that they are refusing to warranty your engine?
Google translate into French if you are having issues reading the above in English below...
Qu'entendez-vous par cylindre 1 est dépouillé? Pourquoi auriez-vous besoin d'un nouveau bloc, les pistons et la culasse?
A brisé le piston, la bielle a traversé le bloc, a les pistons ont causé des dommages tête / de la vanne?
Je sais que l'anglais est pas votre langue maternelle mais je serais curieux de savoir ce qui a mal tourné? Toute image serait génial?
La lecture de vos messages précédents, il semble que vous acheté la voiture en Décembre et avez eu des problèmes avec elle depuis, vous avez eu une des questions en cours avec cylindre 1 ratés par le regard des choses?
Aussi, je ne suis pas sûr si votre voiture est en marche logiciel modifié de l'écu (de reconfiguration) ou une boîte de ferroutage / tuning qui est dupe capteurs pour extraire plus de performance?
Quelle est la qualité du carburant, comme sur l'île de la Réunion? L'indice d'octane? En raison de votre emplacement, un correctif est susceptible d'être très coûteux, nous avons tuners fiables des moteurs et des constructeurs ici au Royaume-Uni qui savent doute être en mesure de régler et reconstruire votre moteur, mais qui est d'aucune aide pour vous lorsque vous vivez sur une île minuscule dans le milieu de l'océan Indien.
Audi ont effectivement refusé une demande de garantie sur la voiture, si oui, pourquoi? At-elle drapeau avec un code de garantie TD1 grâce au logiciel modifié et que vous l'avez écrit qu'ils refusent de la garantie de votre moteur?
MY16 Audi RS6
LOL.RS6chris! wrote:Get your self over to the "remap" thread.....Audi will repair FOC according to info on there?.![]()
Bring it to the UK, all will be fine.
On a serious note, was the car bought from an Audi dealer? If so then responsibility should still sit with them? If not, who did the tune as if the tune is attributable to the failure then you should be looking for redress from the tuner.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
seb de la run
Leo-RS wrote:What do you mean by cylinder 1 is stripped? Why would you need a new block, pistons and cylinder head?
when you open the bonnet,the cylinder 1 is the first cylinder at the left near the light.
audi check the cylinder with camera (endoscopie in french), you can see a lot of stripped, it may be a the failure of pistons ring.
audi refuse to repair because , there is a chip tuning. and they refuse to continue to strip an engine. so i dont know what is the antoher problem
so the cylinder head it may be failure ? or the valve? or other parts.
so i must to drive the rs6 to another garage and check all the problem : cylinder? cylinder head? pistons..
i ask audi, what is the cause?
they say : it may be :
oil
too much breaker engine
spark adavance (octane is ron 93 and the remap is for ron 98)
so if i buy the parts is very expansive, so i would like to buy an used motor with low milage.
bloc in euro : 5600€
boc + cylinder head : 11600€
pistons x8 : 2400€
engine (not used) 25 000€
engine used : 8700€
but i don t trust an used motor...i dont if it was robbed, or crash or failure;...so if all the members have some informations to buy a correct engine, could you inform me...i am disgust, i pay 2500€ / month my credit, i am inflow 40000€...and my rs6 is failure!!!!
so less good solutions is an used motor...do you knwon where and who to contact?
birdiemachine
Christ mate that is grim. Have you no warranty from whoever you bought it from?
It is very unlikely you need a new engine from what you describe, cylinder head off and an inspection of the pistons and valves certainly but I dont think you have done any bottom end damage to the rods or the block itself
You should not have been using 93 octane on a 98 tuned car, recipe for disaster but usually the ECU safeguards the hardware and puts the engine into limp home mode.
Are you on Facebook? There are Audi tuner groups on there where you can ask advice
Audi S/RS Group
Audi RS Tuning
VAG Tuning
You will get better answers on there from dedicated engine rebuild specialists as to what the issue may be and what you can do. There must be an engine specialist on your island somewhere who can take the head off and inspect the pistons and valves?
Audi S/RS Group
Audi RS Tuning
VAG Tuning
MY16 Audi RS6
What tuning are you running Seb?
It can't be that hard to rebuild, new piston, rings, cylinder block, gaskets... Might need to lap the valves but I'd imagine the head would be ok.
You might be able to sell the engine as it is to help fund a 2nd hand engine from the scrapie.
Did you know it had a remap when you bought it and was it stated on the invoice? If not you could try claiming ignorance and go legal. Thats your best move right now.
Again, and ive said it 1000000 times, do NOT assume you have any coverage on ANY part when buying a modified car, you dont. Ive even scanned pages from official audi documents and people still dont listen.
To those, you have it coming. Bend over and open up.
It is certainly safe to assume you have coverage on any unconnected part, done to death elsewhere & this failure even i'd deem as possibly being a result of the tune given the o/p's location amongst other things. Can't imagine MRC rocking up on his island with a dyno for a tuning session.S4WON wrote:Did you know it had a remap when you bought it and was it stated on the invoice? If not you could try claiming ignorance and go legal. Thats your best move right now.
That said, the o/p is being very vague with the tune & purchase details which i find very odd. As you said above, if it was bought unknown then a claim exists with the supplying dealer. If it was bought knowing then a claim surely exists with the tuner.
Paul
Users browsing this forum: Google [Bot] and 203 guests
