Air-con not working.
Re: Air-con not working.
My compressor had a hole in the casing!
System was leaking but until specialist had it on ramps couldn't tell where the leak was.
Bought a 2nd hand compressor for about 250 and I think it came to around 450 totAl to fit...
Still got the compressor - must have chewed some gears or something and shot them through the casing. Fortunately no other signs of impact damage where the exit hole was.
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
- PetrolDave
If the Econ light won't go out then it means that it's stuck in Econ because of a fault.R1RS4 wrote:I thought the Econ light was just to indicate the Econ was on, and when the lights out its in the off mode?Regy53 wrote:i have a issue with my air con the econ light wont go out any ideas possible top up?
Most common is that the aircon needs re-gassing, so that's the first thing to try.
topped the air con up today and all sorted for me
however it was also topped up last year so they put some dye in it for me and hopefully i wont need to but if so can identify a leak
TTS Charged RS4 plus all the goodies
- PetrolDave
Sounds like you've got a slow leak somewhere as it shouldn't need topping up every year ...Regy53 wrote:however it was also topped up last year
I have to top up every 6 months. Will need to get it sorted this year I think.
- PetrolDave
Definitely not right, shouldn't need topping up more often than every 2-3 years at the most.RS6BRIT wrote:I have to top up every 6 months. Will need to get it sorted this year I think.
Have to check that then, thought all was ok as it puts out very cold airPetrolDave wrote:If the Econ light won't go out then it means that it's stuck in Econ because of a fault.R1RS4 wrote:I thought the Econ light was just to indicate the Econ was on, and when the lights out its in the off mode?Regy53 wrote:i have a issue with my air con the econ light wont go out any ideas possible top up?
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
My car had a leak for ages until it was traced to a tiny hole in a pipe underneath a bracket.RS6BRIT wrote:I have to top up every 6 months. Will need to get it sorted this year I think.
Think the garage put a dye in with the gas and removed the front bumper to find where it was leaking from in the end.
Misano Red RS4 B7 Avant
