Those wheels look epic!
Does anyone know the running in policy for the B8?
B8 2015 limited edition Suzuka, pan roof. Love at first blip.
Previous loves: RS4 (B7), 911, Cooper S, 350Z, Civic Type-R.
- Graeme4130
The handbook has a generic Audi policy of certain RPM's up to certain milestones. However, the general consensus is to take it reasonably steady for the first 1000miles and then let rip.ROjj wrote:Does anyone know the running in policy for the B8?
FWIW, the dealer's that I've bought mine from have all said the engine's are run in on a bench and to give it beans from day one without concern.
Also, the cars are test driven flat out straight off the production line on a test area at the factory, so they already have an element of 'shake down' done before you get the car. The dealers PDI is also probably fairly hard on the car as well
There's a million differing opinions on this, but modern performance engines are built with such tight tolerances and lubrication technology's changed quite a bit over the years, so a lot of the old school ideas of not scoring bores etc when parts are still bedding in is mildly obsolete
Personally, I've always gone fairly steady over the first 1k but still used all the rev range, and then given it beans from there on
I think as long as you always make sure the car is nice and warm (oil temp over the first indicated 60deg) before giving it full throttle, you'll not be doing any damage to the engine and then save things like track days etc for when it's done a few k
Brilliant, thanks very much. Loving this forum malarkey!!
Just can't wait to get it now...
- Graeme4130
There's a good thread on running in over on the C7 RS6 forum called 140miles in or something similar to that. Gives some good insights from othersROjj wrote:Brilliant, thanks very much. Loving this forum malarkey!!
worth a read if you're twiddling thumbs waiting for the new car to arrive
Thanks again!
Comments from Audi...
Regarding the running in process, I have spoken with the technicians and they advise me that there is no need to run the car in as all the parts are laser cut; furthermore the RS cars are tested at Quattro GMBH prior to delivery.
However it is worth bearing in mind the gearbox will take ~500 miles to learn and adapt to how you drive.
The other comment the technicians made is that you should never drive the car hard whilst it is cold.
opened the garage door this morning to be awed by this colour after 2 years of ownership
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Lovely pic! Those aren't the 'black' wheels are they?Brooner wrote:opened the garage door this morning to be awed by this colour after 2 years of ownership
Standard rotors. The odd variants have only become available with the end of run clearoutz
yep standard colour but getting them refurbed doing away with the diamond cut
Interesting. All Titanium?
no just the original colour as i have the mirror housings painted to match
Heres my garage door pic
Users browsing this forum: Google Adsense [Bot] and 46 guests
