Bluetooth music options?
MarkPRS6
Re: Bluetooth music options?
Post by MarkPRS6 » Fri May 15, 2015 10:48 am
Sorry to sound like a dummy, but I'm thinking of getting the Aukey unit from Amazon. But where do you connect it to?
Does anyone have a photo showing where it connects? I'm sure plenty of people would find that useful.
I need to sort something out so I can listen to my music via Bluetooth, the radio is usually a waste of time.
Cheers guys.
:blackrs4:
Daytona Grey RS6 with Miltek stainless exhaust and Bilstein coilovers, magic tree air freshener.
Previous : Porsche 911 Carrera 4
Post by Shoppinit » Fri May 15, 2015 10:59 am
Would help if you told us what head unit you are using.
MarkPRS6
Post by MarkPRS6 » Fri May 15, 2015 12:05 pm
RNS-D I believe. It doesn't have the SD card socket. I've got the CD changer in the boot (LHS) and the TV tuner below the CD changer I believe.
Post by Shoppinit » Fri May 15, 2015 12:12 pm
Couple of options, then.
The cheapest and easiest is probably getting the Kufatec Aux-in adapter (or similar) for the TV tuner and then get an Aukey car receiver (like the one I just bought - subject to my pending assessment). Then you just plug the Aukey into the Tuner, select TV from the head unit and you get sound. BUT, the sound quality isn't brilliant through the TV tuner for some reason. http://www.kufatec.co.uk/shop/en/car-hi ... r-tv-tuner
Or you could get an xcarlink. There is a bluetooth option (pricey), but on mine it doesn't sound good when you stream to it. OK for a hardwired connection though.
You could use the xcarlink and Aukey (like I am planning to do).
There might be an aux in adapter that replaces the CD player. Not sure if you want to lose the CD player, though, and I have no direct experience of it. Again, the Aukey will plug into this adapter.
/edit: Kufatec also sell that last. http://www.kufatec.co.uk/shop/en/car-hi ... rns-d-navi
Post by Shoppinit » Sat May 16, 2015 11:14 am
My Aukey turned up. Gonna try it out on the hifi.
MarkPRS6
Post by MarkPRS6 » Mon May 18, 2015 7:52 am
My Aukey also turned up, just need to find out where I can get the adaptor for the TV tuner so I can use it. I'm surprised there isn't an AUX input directly on the TV tuner module as you can select it from the menu.
Post by Shoppinit » Mon May 18, 2015 8:11 am
I linked to it in my reply to you.
MarkPRS6
Post by MarkPRS6 » Mon May 18, 2015 8:33 am
I know, thanks for that but they seem to be out of stock. I'll check again in a few minutes and hopefully order one.
Thanks for your help with this.
Post by Shoppinit » Mon May 18, 2015 9:05 am
There are others, not sure of quality though. Found this after a quick google:
http://www.ebay.co.uk/itm/Video-Adaptor ... 1123568862
Or you could always make your own if you're handy with a soldering iron and be bothered to find the Audi part number for the flat connector. I bet it'd work out more expensive than buying one of the Kufatec ones though.
Post by Shoppinit » Mon May 18, 2015 9:07 am
Which Aukey did you get?
Post by Shoppinit » Mon May 18, 2015 9:13 am
Actually, I wonder if the TV tuner connector has an empty flat connector in it. I can't remember, it was that long ago since I did mine. If so then you coudl just get the pins from Audi for pence and make your own connector. You only need audio, so 4 pins, and a female 3.5mm jack socket. Like this and cut the RCA connectors off:
http://www.amazon.co.uk/3-5mm-Stereo-So ... ack+socket
Or just plug and play with the Kufatec.
MarkPRS6
Post by MarkPRS6 » Mon May 18, 2015 10:28 am
I went for the BR-C3 in the end. I'm chasing Kufatek to see if they can supply the adaptor.
MarkPRS6
Post by MarkPRS6 » Tue May 19, 2015 9:38 am
OK, I've ordered the Kufatek adaptor so hopefully I should soon have all the bits I need to get Bluetooth music up and running.
The next thing will be to get the TV tuner out of the car and work out where all the leads need to connect. I'm going to try and wire everything in alongside the CD changer and put the Aukey unit behind the panel in the boot. That should give a neat solution hopefully. I know I lose the ability to control the Aukey unit from the front of the car but I can't be bothered with routing the cable through the entire car.
I'll try and get some pictures as I do the job and post them in case it helps others facing the same dilemma.
:blackrs4:
Post by Shoppinit » Tue May 19, 2015 10:07 am
If this doesn't put you off, nothing will: ;)
MarkPRS6
Post by MarkPRS6 » Tue May 19, 2015 1:25 pm
What is the part arrowed in red?
Users browsing this forum: Google [Bot], Google Adsense [Bot], rs4wagon and 45 guests
