low coolant
jamiedal
low coolant
Post by jamiedal » Tue Apr 28, 2015 5:02 pm
Hi everyone,
I've had my car for around 2 weeks (06 plate on 66k) so decided to do an oil check and coolant check, I discovers the coolant was about an inch under the minimum line and it was perfect when I picked it up from the dealer
Is it worth taking it back to them to check or should I fill it back up and see if it happens again first?
Any known leak points I could check easily?
Jamie
Ellis
Re: low coolant
Post by Ellis » Tue Apr 28, 2015 5:10 pm
Check auxiliary radiators. Known to weep/leak due to corrosion.
Look through the 2 lowest bumper grilles left/right and look for any signs of coolant colour fluid sitting on or around the radiator fins.
Stairs
Re: low coolant
Post by Stairs » Tue Apr 28, 2015 5:18 pm
Take it back, my Aux Rad had gone when I bought the car... Sit still and get the engine over about 105 degrees then you should see steam coming from either headlamp, that is one indication.
I took mine back and got told that it was not covered under warranty and that it could have happened in the 4 days I had owed the car.
Hit them with the 'sale of goods' act, the car is not fit for purpose as sold, worst case take them to court, as long as you complained to them pretty quick I am pretty sure you would win. but my guy caved in straight away and replaced it.
jamiedal
Re: low coolant
Post by jamiedal » Tue Apr 28, 2015 5:19 pm
Yeah I just checked and the left hand side aux rad seems to have some fluid on the bottom of it and the right hand side one is completely dry
geordie jay
Re: low coolant
Post by geordie jay » Tue Apr 28, 2015 6:14 pm
you only need one aux rad really,, take the drivers side out and put in a caf and put the rad that's not leaking on the passenger side,,i,ve done it like a few on here..
Ellis
Re: low coolant
Post by Ellis » Tue Apr 28, 2015 6:16 pm
As above, if you don't get any luck with your dealer then I would explore the CAF option.
jamiedal
Re: low coolant
Post by jamiedal » Tue Apr 28, 2015 6:45 pm
I'll see how I get on with the dealer tomorrow and report back...Thanks
gars7
Re: low coolant
Post by gars7 » Wed Apr 29, 2015 10:53 am
Jamiedal, I offer the following points based on recent expensive (US$4,300) experience in my wife's 2004 S4 Avant with 106k miles on the clock. She pulled a red coolant warning light with subsequent high temp readings.
Towed car to Audi, with the following findings:
Found top radiator hose blown apart.
Found the water pump, coolant overflow hose and secondary radiator to be leaking coolant
Found front crank seal to be leaking oil
Found oil pan to be leaking oil
Found oil filter housing and valley pan gasket to be leaking oil. (Note, we never had any oil leak show on the garage floor - it collected in the engine valley.)
Good luck with you coolant issue. At minimum, these are other places to look.
__________________
2014 RS7 4dr HB Quattro Tiptronic Phantom Black Pearl Effect Carbon Optics 4.0L TFSI V8 Prestige
2010 Q5 4dr SUV Quattro Tiptronic Garnet Red Pearl Effect 3.2L V6 Premium Plus
2009 A4 4dr Sdn Quattro Tiptronic Phantom Black Pearl Effect 2.0T Premium Plus
2004 S4 5dr Avant Quattro Tiptronic Light Silver Metallic 4.2L V8
Ellis
Re: low coolant
Post by Ellis » Wed Apr 29, 2015 11:22 am
Shitting hell, I hope it isn't that for the sake of the OP.
jamiedal
Re: low coolant
Post by jamiedal » Thu Apr 30, 2015 1:17 pm
Just to keep you all updated...took it back down yesterday and they put it in the workshop straight away and gave me a courtesy car to run about in, should be sorted early next week hopefully
Stairs
Re: low coolant
Post by Stairs » Thu Apr 30, 2015 6:12 pm
jamiedal wrote:Just to keep you all updated...took it back down yesterday and they put it in the workshop straight away and gave me a courtesy car to run about in, should be sorted early next week hopefully
Good stuff, is this a main Audi dealer or a Indy?
geordie jay
Re: low coolant
Post by geordie jay » Thu Apr 30, 2015 7:32 pm
sounds like a dealer...and if it is they wont want to drop a aux rad but tell you to keep both haha,,then they will give you all the warranty crap speech
jamiedal
Re: low coolant
Post by jamiedal » Fri May 01, 2015 2:42 pm
Just had a phone call off the garage, passenger side aux radiator was leaking and driver side wasn't looking to clever either so both radiators were replaced....picking her up tomorrow
geordie jay
Re: low coolant
Post by geordie jay » Fri May 01, 2015 4:25 pm
Haha typical audi..if in doubt replace everything...
mf51y
Re: low coolant
Post by mf51y » Fri May 01, 2015 8:25 pm
What's the going rate for a replacement radiator??
Mugello blue avant black optics...Nearly standard...milltek resonated valved, spaced 10 rear 8 front☺
