Calling all you B7 guys running 10x20" wheels
N11LS_J
Post by N11LS_J » Sun Apr 26, 2015 8:42 pm
Talk to me, what offsets and tyre sizes you running?
Rubbing issues?
Instagram : n_i_l_s
maars
Re: Calling all you B7 guys running 10x20" wheels
Post by maars » Mon Apr 27, 2015 7:51 pm
Not changing your wheels -again- ?!!
Not feeling those wide 19s eh?
N11LS_J
Post by N11LS_J » Mon Apr 27, 2015 9:13 pm
Haha, those are now on my widebody S4, look so much better on there
Which means I'm on the hunt for some more 20s for the B7
Instagram : n_i_l_s
Covkiller
Post by Covkiller » Mon Apr 27, 2015 9:20 pm
I now run S7 20" ET29 with 4mm spacers, 235 30 20 Michelin Pilot SS, lowered on KW V3 63cm front 64cm rear (ground to top of wheel arch) and adjustable top arms. Also had my wheel arches flattened at my mates body shop. I have no rubbing now.
This wasn't the case originally.
I used to run 5mm spacers, 255 30 20 Vreds, rolled arches, 64cm front 65cm rear with standard arms, I had rubbing and inner tyre wear. It did my head in. :drink:
May the lowered be with you my son.
:nogarors4:
Post by MikeFish » Mon Apr 27, 2015 9:23 pm
Covkiller wrote:I now run S7 20" ET29 with 4mm spacers, 235 30 20 Michelin Pilot SS, lowered on KW V3 63cm front 64cm rear (ground to top of wheel arch) and adjustable top arms. Also had my wheel arches flattened at my mates body shop. I have no rubbing now.
:nogarors4:
But these are 9" rims right?
Covkiller
Post by Covkiller » Mon Apr 27, 2015 9:52 pm
Yep
maars
Post by maars » Mon Apr 27, 2015 10:17 pm
Look at the stretch on those!
Looks like you sprayed the tyres on!
They make the RS4 style rims in 9.5 & 10 x 20, but with odd offsets.
So is ET29 with a 4mm spacer ET25 or ET33?
Post by MikeFish » Mon Apr 27, 2015 11:23 pm
ET25
N11LS_J
Post by N11LS_J » Tue Apr 28, 2015 12:09 pm
I'm trying to work t the perfect offset on 10x20s, with 255 tyres
I had the same wheels as Covkiller and had a lot of rubbing, I'd like to stick to 255 tyres hence my reason to go to 10j wide wheels
Instagram : n_i_l_s
Covkiller
Post by Covkiller » Tue Apr 28, 2015 12:51 pm
maars wrote:Look at the stretch on those!
It is ET33 as you add 4mm more offset from the face of the wheel
hvm5
Post by hvm5 » Tue Apr 28, 2015 1:00 pm
I was looking at C6 RS6 Wheels, 9x20, Et38 and would have gone for 265/30 tyres but in the end decided 19's suit the car best.
Covkiller
Post by Covkiller » Tue Apr 28, 2015 1:10 pm
It also depends on the physical form / structure of the wheels. I would say the very best way is to be in touch with a member with the same wheels and tyres you wish to fit and the ride height and camber.
N11LS_J
Post by N11LS_J » Tue Apr 28, 2015 3:24 pm
Adding spacers pushes the wheels further out reducing the offset, so it would be ET25
Higher the ET, the further the wheels sit inwards
Instagram : n_i_l_s
Bladerider
Post by Bladerider » Tue Apr 28, 2015 3:40 pm
That question can be taken either way - hence why two people have given different answers lol
If you have a spacer it LOWERS the ET, so an "ET29 with a 4mm spacer" could mean an ET33 wheel fitted to a car as well as a 4mm spacer or it could mean whats the equivalent offset an ET29 wheel if I fitted a 4mm spacer, which would be ET25. lol
Hence why your question could be interpreted either way.
J
Post by MikeFish » Tue Apr 28, 2015 4:57 pm
N11LS_J wrote:I'm trying to work t the perfect offset on 10x20s, with 255 tyres
Nils you shouldn't have had any rubbing with 9x20 ET29 and 255 tyres unless you were really low. Mine are ET26 and don't really rub (or maybe even not at all).
Have you played with camber settings to avoid rubbing? You can dial in a bit of negative camber to give you that mm or 2 clearance without getting loads of tyre wear.
Users browsing this forum: No registered users and 128 guests
