New brakes, light still on
Had brake wear light come on quite a bit the end of last season, presumed the pads were worn so ordered AP discs and premier pads, just got the car out of hibernation and swopped brakes (pads only 1/3 worn), warning light still on, I've re checked plugs and connections seem fine, looking at Vagcom its suggesting an intermitant open circuit, reset faults and drove 3mls, no problem, then started car to drive back and the light came straight back on, any ideas??
R8 V10 Spyder
previous toys RS4 B7, 993RSR, 993 Turbo S, 944/68 S/C racercar, 996 C2, 993 C2, 944 S2, 944
Re: New brakes, light still on
I had this problem when my new OEM pads were fitted. Turned out to be a poor connection from the new pad connector to the existing loom, even though the connections seemed fine.
+1maars wrote:I had this problem when my new OEM pads were fitted. Turned out to be a poor connection from the new pad connector to the existing loom, even though the connections seemed fine.
If the seal gets left out of the plug (previous pad changes) moisture can corrode the socket pins
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
Thanks guys, re inserted plugs a few times with switch cleaner and seems to have fixed it
R8 V10 Spyder
Users browsing this forum: No registered users and 174 guests
