DRC Suspension Issue
Re: DRC Suspension Issue
Yeah - that's a weird one, the rumour is that audi spec'd these cars to be as faithful to the rs2 as they could. Clearly that means less tech.
So no heated seats - but i had it for two days in cold weather and didn't miss them
For me my next car had to have a sunroof
It looked stunning though, walking back to it in the sun was awesome. Id have bought it there and then if it had a sunroof.
Ive ended up now going for a ltd edition car, just not a nogaro selection
Zero Drama
Interesting thread. For the record my early (2012) model has no knocking.
But it is at the time of writing in the main dealer to repair a fault they found at the 34,000 mile service. They found a fault in the passenger side front damper unit in that it is leaking hydraulic fluid. The part has been couriered from Germany and requires a special tool to refit.
While it's given me no problems I have long regretted having the D RC system fitted just because it never feels right. I have heard that the standard springs are a much better ride.
Good luck with your efforts to get your car fixed - you will need it as the individual versus the international conglomerate has little chance.
- Revolution
- Trader (Expired)
2) Failures not repaired (characteristic of the car) ;
Simon82 - Sept 14 car, 7k miles. Both front shocks knocking
WilliamPilot - Sept 13 car, 6k miles. Both front shocks knocking (Swindon Audi have looked)
Revolution Glenn - June 14 car, 1500miles drivers front and near side rear (newcastle audi)
3) No Failures ;
Graeme 4130 - Sept14 car 13k miles
3) No Failures ;
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Revolution Glen..... I have just added your details to the DRC Survey post. I hope you don't mind !!!!
Cheers !
Cheers !
Current: 2014 Sepang Blue B8 RS4
Previous : B7 RS4
Previous : Subaru 22B UK
Previous : Subaru Sti Type UK
Previous : VW Golf GTD
Previous : B7 RS4
- Revolution
- Trader (Expired)
That's fine Ricky.
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Glen why don't you put one of you coilovers kits on and have a play,I'm sure others would be interested to see the results
- Revolution
- Trader (Expired)
We have loads of plans for it inc lowering the RS but I ticked the box for DRC to try and see if we can build a lowering kit to work with this....
It's become a principle with Audi now as I offered to remove thd DRC and go aftermarket it if they refunded me the difference between a ats shock set up and they politely refused - let's see how I get on.
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Glenn. I also asked them to remove my DRC and fit my car with the standard set up and refund the difference ! They refused again, and said no goodwill was necessary as there was 'no fault' with my DRC.
Audi definitely know how to take the piss. Do they think we are stupid ? No they don't. Do they think no one will take a multi national on......Probably........ and they are relying on it !!!!!! I would love to see them beat over this on going issue for nearly 13 years now, but don't expect it to happen. The only way I'd expect to see any result is pick the biggest Audi event of the year and all owners with DRC faults appear and display their cars at the entrance. Unfortunately embarrassment is the only thing which works in my opinion !!!!
Previous : B7 RS4
Previous : B7 RS4
Maybe I've been lucky, but I had no problems with my B7, which covered almost 40,000 miles and so far no issues with my B8, which has done a little over 3000 miles. It maybe worth noting that in both instances my car has been built towards the end of the production life, my B7 was a 57 plate and I took delivery of my B8 in January, although the fact that the problems still exists with some B8's would suggest build date is irrelevant. Does anyone have any idea of how many cars are affected in relation to cars on the road?
My RS6 had countless drc issues - it spent a lot of time having shocks replaced and the system repressurised, my b8 isn't here yet so no room to comment on that one yet
Zero Drama
- Revolution
- Trader (Expired)
sad times Ricky...Ricky wrote:Glenn. I also asked them to remove my DRC and fit my car with the standard set up and refund the difference ! They refused again, and said no goodwill was necessary as there was 'no fault' with my DRC.
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Apologies if this is a blonde moment but why did you chaps spec DRC when the cars can be had without it
TX.
TX.
I had a knocking from my front drivers side (w/ DRC). They have replaced both shocks and recharged the system. I got it back on Friday however due to having an op last Wednesday I cannot drive it until Wednesday, but I will report on whether its worked.
MY15 Audi B8 RS4 Avant - sports pack / black optics / sports exhaust / Rotors / Technology Pack High w/ google maps, wifi etc / lane assist / radar cruise / memory pack etc etc - panther black on black on black on black.... with some extra black for good measure!
The dumb assumption they'd have fixed it!!!Terminator_X wrote:Apologies if this is a blonde moment but why did you chaps spec DRC when the cars can be had without it![]()
TX.
- Revolution
- Trader (Expired)
just heard from one of my customers this morning he's had his DRC fixed on his B7....
2 new shocks free of charge & re gassed system a year after he bought the car as a "gesture of goodwill"
so it seems the B7's are still getting sorted but not the B8's
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Users browsing this forum: No registered users and 44 guests
