Running a wire from the passenger cabin to under the bonnet.
5.0 V10 50v biturbo - 571 bhp
stt
Post by stt » Fri Mar 27, 2015 1:08 am
Does anyone know if there is an existing grommit that I can use to run a few wires from the passenger compartment through to under the bonnet?
Also does anyone have a how to on how to remove the grille?
I need to get my car 'work ready ' ;-)
C6NVS
Re: Running a wire from the passenger cabin to under the bon
Post by C6NVS » Fri Mar 27, 2015 4:53 am
Open the bonnet.
On the drivers side, underneath the fire wall cover right up near (and under) the windscreen is a black plastic compartment (you will have to remove the rubber strip and cover that both run the width of the engine bay just up under the windscreen to see).
There is a fuse box that runs wiring from the engine bay into the interior through a slot inside the box.
You will need to remove the screws that hold the box cover on.
Once you have the top off, you will see where the wiring runs into the interior.
The slot is also visible under the dash from the inside when the lower covers are taken off in the footwell.
Edit: the cover to the box does take some work to remove from under the windsreen area. You may want to remove the wipers and lower windscreen cover if you have difficulty.
This is where we run the wiring for WMI.
Grille best removed with front bumper removal.
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
C6NVS
Post by C6NVS » Fri Mar 27, 2015 4:56 am
stt
Post by stt » Fri Mar 27, 2015 5:50 am
I'll give it a go in the next few days
R33
Post by R33 » Fri Mar 27, 2015 11:20 am
Work ready? Blue lights?
stt
Post by stt » Fri Mar 27, 2015 11:49 am
Correct ;-)
GC1978
Post by GC1978 » Sat Mar 28, 2015 5:14 pm
Would love to see your BLU insurance costs on an RS6!!
Users browsing this forum: No registered users and 69 guests
