Cut off
5.0 V10 50v biturbo - 571 bhp
9kade
Cut off
Post by 9kade » Sat Mar 21, 2015 8:03 pm
Hi all any one can help me my original cut off valve (blow off) is broken because of the high pressure air that comes from the boost so where can I find heavy duty cut off valve so It can take the high pressure
(That cut off valve is comes under the intake left and right side )
Audi RS6 2009 C6
leet
Re: Cut off
Post by leet » Sat Mar 21, 2015 10:33 pm
I'm no expert on the C6 RS but genuine Audi blow off valves are usually more than adequate and generally more reliable than aftermarket options. If it was mine, I'd be buying new oem parts
classba
Re: Cut off
Post by classba » Sun Mar 22, 2015 12:54 am
The blow off valves cannot be changed on their own, they are part of the air filter boxes. I'm running 9XX ps and have no issues with stock oem ones running 1.4 bar of boost.
Ungjaevel
Re: Cut off
Post by Ungjaevel » Mon Mar 23, 2015 1:21 pm
9kade wrote:my original cut off valve (blow off) is broken because of the high pressure air that comes from the boost
It's function is to cut/blow off pressure >X bar/psi. It's not broken because of that. Perhaps due to particles in the system?
9kade
Re: Cut off
Post by 9kade » Wed Mar 25, 2015 8:24 am
Thanks All
Ungjaevel
Re: Cut off
Post by Ungjaevel » Wed Mar 25, 2015 2:03 pm
Did you fix it? If so what was the problem?
Users browsing this forum: No registered users and 44 guests
