Side lights on permanent
Hi all, the off side side lights on my c5 are on all the time, is this a symptom of some thing specific , or just a random fault? Cheers .
Re: Side lights on permanent
Have you left the indicator stalk up / down?
Haha, nice one! ....... No, I haven't left the stalk up, the only way to turn the lights off is to disconnect the battery, I've had to take the front bulb out to stop it draining the battery, it's probably a random fault, I was hoping someone had experienced it before.
You need Ross-Tech with this car. Just scan and you should have an answer, some sensor or maybe bad stalk? First you said side, then front, is it just the little side blinkers?
Revo Tune + extra ME7 fueling - MTM TCU - Wagners - Koni Struts - DevilSown W/M - Michelin PSS's - Hotchkis Sways - Upgraded TC/Trans - Mugello/Black/Carbon
Hazard light switch unit is my guess. It's the hazard light switch but also controls the indicators. £50 part from dealer and an easy DIY fit on driveway.
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
Sorry I've just read that again - Doh! I thought the OP said the indicators were stuck on. Ignore that last comment if you've not already done so.drybeer wrote:Hazard light switch unit is my guess. It's the hazard light switch but also controls the indicators. £50 part from dealer and an easy DIY fit on driveway.
Users browsing this forum: srichards and 57 guests
