C5 headlight adjusters (nylon gears)
SuprSi
Post by SuprSi » Thu Mar 19, 2015 10:01 pm
I'm doing a headlight refurb soon, fitting new projectors Trups supplied, I want to get before / after pics but the headlight alignment was a bit pants, I've gone to set them right and ALL of the bloody nylon gears are slipping on the knurled shafts.
I've had a quick Google search and found nothing, are the nylon gears available on thier own? I've tried epoxy, that failed miserably.
CheeRS :)
Trups
Trader (Expired)
Re: C5 headlight adjusters (nylon gears)
Post by Trups » Thu Mar 19, 2015 11:11 pm
Is that on the outside its slipping? Where the plastic meets the metal coming from inside?
Trups
SuprSi
Post by SuprSi » Thu Mar 19, 2015 11:49 pm
Hey Trups, Yep that's the bits. Whoever had it last bodged one by winding an 8mm nut on but now the other 3 are slipping too :(
4everRS
Post by 4everRS » Fri Mar 20, 2015 5:56 am
I don't check the site that often, but saw this and thought I'd share what I did.
The nylon gears are prone to failure.
Remove the gear
Carefully drill a tiny hole in the end of the knurled pin
You'll have to hold it so it doesn't push in
The hole is needed so you can tap a tiny screw in the end to be able to hold the knurled pin out. Carefully put jb weld in the hole on the nylon gear, and slide on the pin. As your doing so, you'll have to get your screw or nail ready to go on the drilled hole and pull the pin outward, sliding the gear on further.
Let dry and your done. And still adjustable.
That or buy a new headlight.
C5 RS6 sedan - Avus/Ebony - Viper Stage 2 ECU/TCU - water/meth - gutted precats
SuprSi
Post by SuprSi » Fri Mar 20, 2015 12:35 pm
Thanks 4everRS,
That's more or less what I did, although without pulling on the shaft. I might have to try again with your method. It's a pretty stupid design!
Post by bam_bam » Fri Mar 20, 2015 1:27 pm
SuprSi wrote:Thanks 4everRS,
*snigger*
SuprSi
Post by SuprSi » Fri Mar 20, 2015 5:09 pm
Lol, trust you! That is quite funny tho. xD
4everRS
Post by 4everRS » Sun Mar 22, 2015 1:29 am
Yeah, it's really important to be able to pull that pin outward while sliding the gear on. Mine's been holding great for several months now.
R5XVB
Post by R5XVB » Sun Mar 22, 2015 10:31 am
Slight tangent but related...
I replaced my headlights with 'Angel Eyes' on a 4BH Allroad, the self levelling motor connectors (electrical) were a different size and as I noticed later three wire versus four wire. Not bothered, I thought removing the dash error message would be a breeze as the loss of thus function was no biggie. How wrong was I? You can't delete it... :audibash:
So thought ok reconnect the old motors and hide them away, oh yeah that's right yesterday was bin collection day. Muppet. So my options are to splice the wires over the correct resistance or source another set of these levelling motors. Anyone got any or know what resistance is needed to pretend to the system that these motors are still physically present?
Cheers...
SuprSi
Post by SuprSi » Sun Mar 22, 2015 12:35 pm
You could try 100ohm resistors, that will mean ~140mA and nearly 2 watts, you'll need the ceramic type as they'll get a bit warm.
These can cope with 5 watts so will be perfect.
http://www.amazon.co.uk/Radial-Ceramic- ... B00857S6YM
R5XVB
Post by R5XVB » Mon Mar 23, 2015 12:15 pm
SuprSi wrote:You could try 100ohm resistors, that will mean ~140mA and nearly 2 watts, you'll need the ceramic type as they'll get a bit warm.
Ta muchly. :)
Users browsing this forum: asgor, srichards and 84 guests
