I've had a quick Google search and found nothing, are the nylon gears available on thier own? I've tried epoxy, that failed miserably.
CheeRS
*snigger*SuprSi wrote:Thanks 4everRS,
That's more or less what I did, although without pulling on the shaft.
Yeah, it's really important to be able to pull that pin outward while sliding the gear on. Mine's been holding great for several months now.SuprSi wrote:Thanks 4everRS,
That's more or less what I did, although without pulling on the shaft. I might have to try again with your method. It's a pretty stupid design!
Ta muchly.SuprSi wrote:You could try 100ohm resistors, that will mean ~140mA and nearly 2 watts, you'll need the ceramic type as they'll get a bit warm.
These can cope with 5 watts so will be perfect.
http://www.amazon.co.uk/Radial-Ceramic- ... B00857S6YM
