Those with small plates
Those of you with smaller front plates, How are you attaching them to the grill?
I've just and my plates made up, Don't really want to just stick them to the longer front plinth.
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
Re: Those with small plates
on my C6 I took the longer plinth off, then drilled the plate to align with the holes that hold the plinth on, I remember doing something similar with the b7 before.
alternatively you can get a plate holder that screws in the tow eye hole, I have that too but my small plate looked really really small when offset to one side, again slightly different on the B7
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
Mine is just screwed straight on to the grill using the existing holes from the plate holder. Just use some longer screws and jobs a good'un'Macdaddy wrote:Those of you with smaller front plates, How are you attaching them to the grill?
2016 BMW F80 M3
2014 B8 RS4 - Milltek Non-Res - KW V2's with DRC delete - Setup by Centre Gravity. - Sold
2013 Q5 2.0 Tdi
1997 BMW E36 328i track car
2013 Q5 2.0 Tdi
I'm in the process of buying a 4 digit plate and have enquirered with Audi and it's no trouble to get a short backing plate whether it's from US or UAE parts list I don't know but your local dealer can supply
Do you move the plate holder to one side to remove?
- Vodkaking77
I used the holes for the plate holder and the same screws.
Currently my plate is in my window cos i love the massive grill. Looks meaner.
First pic with small plate Now with in the window
I used the original back plate and cut out the middle section with a chop saw, masked it all up first with duck tape so it didn't split when I cut it.
I also purchased a spare one from Audi just incase £76, but will need it anyway when I go to sell.
Current 2014 RS4 Sepang with optics, buckets.
997 Turbo Cobalt Blue
Previous:-
996 C4S
B7 RS4 Avant Sprint blue
B7 RS4 Saloon Sprint blue
MK5 Golf R32
MK4 Golf R32
Evo 8 & 6
Many golf GTI's
Previous:-
996 C4S
MK5 Golf R32
MK4 Golf R32
Evo 8 & 6
Many golf GTI's
Plenty of options suggested thanks
Also prefer it without a plate tbh.
I removed the plate holder and measured the holes on the car where the plate holder was attached to correspond to my new plate. Then drilled and fitted them into the original holes on the car.
however I did not like where the screws showed on my plate as it was half on the black lettering and half on the White back ground.
I then decided to get the pressed metal plates as I like the look of them. In order for me to attach this to the car without drilling the new pressed plate I counter sunk the holes on my old shortend plate and stuck the new pressed plate directly on top off it.
The pressed plate hides the old plate perfectly and looks good.
U don't have to use ur old plate u can also just make a small bracket out of thin sheet steel or stainless, drill and countersink the two holes and stick ur new plate directly to the new steel holder. Which will also eliminate the need for screw caps showing on your plate.
Users browsing this forum: AndyBrad and 38 guests
