Need some desperate help with vibrations when accelerating
Re: Need some desperate help with vibrations when accelerati
What about the centre driveshaft bearing, or rear diff mounts?
Daytona RS6 Avant
Hi Nobby, did you mean the centre/front propshaft bearing?Nobby wrote:What about the centre driveshaft bearing, or rear diff mounts?
Not sure if they've checked the rear diff mounts though, so will ask them to check these as well when the car's in on Thursday.
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
If the vibrations are oscilating rather than constant, I'd guess it's a balance problem where one wheels vibration is balanced out by another wheel's vibration. When the balance errors are in phase with each other, you'll get the vibration, when they're out of phase they will correct each other.
I'd be starting with a wheel balance check in these curcumstances!
Recycling dinosaurs for fun
Cheers Sweegie, I'll get it booked in and report back.sweegie wrote:If the vibrations are oscilating rather than constant, I'd guess it's a balance problem where one wheels vibration is balanced out by another wheel's vibration. When the balance errors are in phase with each other, you'll get the vibration, when they're out of phase they will correct each other.
So according to my new found friends at 4 Rings, the problem is fixed. It turned out to be the inner and outer CV joints had zero grease in. They lubed it all up and took it for a test drive and all was well. Thank goodness I didn't have to dive into the RS6 fund again. Now just got to get the steering rack replaced and it will sadly be up for sale!!!! More on that later.
By the way, thanks to all of you for the help and suggestions.
Shame you have to sell it after all that!
RS6 C5, MTM
'Tis true but when I first bought the car, I had a feeling I'd struggle with the dated interior and unfortunately compared it to the BMW I had before.Steveo wrote:Shame you have to sell it after all that!
I'm glad I've experienced one and I definitely don't regret it, even though it's tried to destroy my slush fund!!
Which BM is that then? Cos I find my M3 interior much less sophisticated than my Rs6 one.
E61 M5Shoppinit wrote:Which BM is that then? Cos I find my M3 interior much less sophisticated than my Rs6 one.
Nice.
glad to know its fixed, mine has started with a similar noise, can see grease in the passenger side alloy wheel so assume its the same, is this the place you took yours for reference
http://www.4ringsmotors.co.uk/4rings.htm
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
No this is the place mate;RS6JJL wrote:glad to know its fixed, mine has started with a similar noise, can see grease in the passenger side alloy wheel so assume its the same, is this the place you took yours for reference
https://plus.google.com/106018183401522 ... l=uk&hl=en
You will more than likely speak to Dean who's a good chap.
Hi,hope you got this one cured but I agree with Shop,had similar fault on a mark one A4 that turned out to be the gearbox end driveshaft cup spline worn and allowing the inner end of the shaft to wobble around under harsh acceleration,took some finding
Duh,just seen you've got it licked,damn ipad not updating properly
Users browsing this forum: B_O_N_K and 20 guests
