Carbon clean with DIY walnut shell blaster
DaytonaRs4
Re: Carbon clean with DIY walnut shell blaster
Post by DaytonaRs4 » Thu Feb 19, 2015 6:46 am
Im looking at doing this soon..
i have all the tool's etc required can someone confirm that the following gaskets are required?:
2 x intake gaskets 079 133 074 B
2 x vent tube O rings (no P/N)
1 x Throttle body Gaskets
other than the one way valve prev mentioned earlier in posts are there any other specific parts that i will need for rebuild
thanks
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
TonyHayers
Post by TonyHayers » Thu Feb 19, 2015 10:56 am
You don't need to bother with throttle body gasket, it's just flat metal iirc. Just put it somewhere safe.
I replaced my intake gaskets, but it sounds like a lot of people don't bother. Mine probably didn't need it tbh.
What are the vent tube O rings?
06 Phantom Black Saloon:
^ GONE :cry:
docurley
Post by docurley » Thu Feb 19, 2015 4:09 pm
I think he means something like this.
Lukes3
Post by Lukes3 » Thu Feb 19, 2015 6:34 pm
O rings are fine to use again, just put a bit of grease on them before puting it back together.
mark260684
Post by mark260684 » Thu Feb 19, 2015 8:48 pm
Brilliant bit of information. Wish I had known this before I did mine a few months back.
B7 Sprint Blue RS4 Avant,
Milltek non res non valve cat backs,
Decoke,
034 Motorsport alloy intake flap arms,
Led interior bulb kit,
Led drls and side lights,
DaytonaRs4
Post by DaytonaRs4 » Fri Feb 20, 2015 12:09 am
yeah i got the info from the ECs tuning website as mentioned above. all my gaskets were replaced last year when Autohaus did a CC for me, i think i will just play safe and get new intake gaskets and re-use the rest.
thanks for the info guys
TonyHayers
Post by TonyHayers » Fri Feb 20, 2015 10:29 am
Good luck! post some photos :)
^ GONE :cry:
bazza138
Post by bazza138 » Sun May 03, 2015 3:25 pm
Great post tony !!
I'm started mine today ! I'm stuck here ! I can't get the back off by the breather hose from the coolant reservoir !!
Am I missing something simple!!!
RS6BRIT
Post by RS6BRIT » Mon May 04, 2015 3:39 pm
follow this link and it will show you the full step by step guide on removing the manifold mate.
http://audirevolution.net/forum/index.php?topic=439.0
Remember you WILL need a very small ratchet into which a T30 (from memory) bit will DIRECTLY fit. anything larger and you wont get in the gap. This is at the oil separator/ coolant connection stage.
bazza138
Post by bazza138 » Mon May 04, 2015 9:10 pm
Awesome link thanks ! I just need a t30 bit , I got one ! But it's on a 1/4 socket ! Just that to come off then bingo ! CC time ! I post up the progress
TonyHayers
Post by TonyHayers » Tue May 05, 2015 10:53 am
Yeah, it's very tricky, but follow the link for the removal guide and it will tell you where the bolts are. The lowest one is a pain. I couldn't remove the SAI pipes so access to the bottom one is very very tight. You need a very low profile ratchet like the one I mention early in the thread and then grind down a normal T30 bit so that only the driver bit protrudes. Just keep trying and you'll get there eventually.
^ GONE :cry:
bazza138
Post by bazza138 » Wed May 06, 2015 3:30 pm
I must of missed the bit about grinding down a bit, I got all the others bits off your write up :) I have a go on sat ! Image
bazza138
Post by bazza138 » Fri Jun 05, 2015 4:07 pm
Long time away from doing this , but 1/2 off work to try this :)
But started doing this bloody Hoover has given up !!! Ffs
Now off to buy cheap Hoover
bazza138
Post by bazza138 » Fri Jun 05, 2015 5:43 pm
Dose any know the firing order ! Would make my job a lot easier as gotta push the heavy girl up and down the drive ?
coffey555
Post by coffey555 » Sat Jun 06, 2015 9:44 am
1-5-4-8-6-3-7-2
Misano Red RS4 B7 Avant
Users browsing this forum: Google [Bot] and 191 guests
