RNSE Aux / ipod cable for sale
- RossDagley
- Top Gear
Re: RNSE Aux cable
You need some radio keys (like £2 on eBay and well worth having handy!) and then route the cable to the glove box or armrest which ever you fancy. You'll need to drill a small hole in the glovebox or wherever to route the cable through unless you come up with a more imaginative way of routing the cable - but it's very simpleDonkey99 wrote:Im interested in one too, how do you get the radio out and where are you guys routing the cable end to? Ta
Previously:
Previously:
Re: RNSE Aux cable
Hi Ross,
I'll take one if you have any lef
Pm me the payment details.
Sprint Blue known as Blueberry Beast
- RossDagley
- Top Gear
Re: RNSE Aux cable
All PM's replied to!
Previously:
Previously:
Re: RNSE Aux cable
Any left, I'll have one if so!
repsol honda fireblade.
- RossDagley
- Top Gear
Re: RNSE Aux cable
Hi rocket.
Yep some left!
PM me and we'll swap details
Yep some left!
Previously:
Previously:
- RossDagley
- Top Gear
Re: RNSE Aux cable
All should now have been delivered. I've still got some left from my second batch if anyone else needs one
Previously:
Previously:
Re: RNSE Aux / ipod cable for sale
i,ll paypal you tonight!!
- RossDagley
- Top Gear
no rush duderocket1 wrote:i,ll paypal you tonight!!
One here waiting for you when you need it
Previously:
Previously:
Job done.
Pulled out the RNSE using the keys - had to drop the drivers side under dash trim so I could give the unit a push from the back. Fitted the plug and cable tied to rest of the loom for strain relief. Pulled out cd changer in glove box and then fiddled cable thru to back of glove box. There was oblong hole in back upper shelf in glove box to left of the cd changer so enlarged this a bit and threaded the 3.5mm jack into the glove box. This leaves just enough cable for passenger to operate the device when attached. Recoded using Vagcom.
All works - music from iPhone plays thru aux in.
Input level is bit low even with volume on iPhone at max (likely the load presented by the RNSE is bit low compared to a set of headphones) but audio quality is great (I rip at high bit rates).
Thanks for making the cable Ross.
Daytona RS4
What was the coding required through Vagcom please mate?PaulT wrote:Job done.![]()
Pulled out the RNSE using the keys - had to drop the drivers side under dash trim so I could give the unit a push from the back. Fitted the plug and cable tied to rest of the loom for strain relief. Pulled out cd changer in glove box and then fiddled cable thru to back of glove box. There was oblong hole in back upper shelf in glove box to left of the cd changer so enlarged this a bit and threaded the 3.5mm jack into the glove box. This leaves just enough cable for passenger to operate the device when attached. Recoded using vagcom.
Hi,
Ross references coding changes needed in page 1 of this thread. I followed these it was easy.
Paul
Paul
Daytona RS4
- RossDagley
- Top Gear
Thanks for the feedback and detailed guide mate - hopefully helps others
Great to hear it all works!
Cheers!
Ross
Cheers!
Ross
Previously:
Previously:
