RS6 Project 7XX
Re: RS6 Project 7XX
Sorry I made a mistake not uprated valve train. we re newed the exhaust stock valves, springs & lifters, rollers and are using NA exhaust cams
I
I
Re: RS6 Project 7XX
So what are the Dyno numbers, post a sheet? So which Fast and Furious is your favorite?
Nice build though!
Nice build though!
Revo Tune + extra ME7 fueling - MTM TCU - Wagners - Koni Struts - DevilSown W/M - Michelin PSS's - Hotchkis Sways - Upgraded TC/Trans - Mugello/Black/Carbon
Re: RS6 Project 7XX
No numbers as yet only just run in the motor and have on a safe map. Due to finish off soon.
Fast and Furious.. Number 1 is best!.
Re: RS6 Project 7XX
You are correct!TTE Si wrote:No numbers as yet only just run in the motor and have on a safe map. Due to finish off soon.
Looking forward to seeing the numbers. Out of interest, any work on the air intake or just stock box? Surprised you didn't just scrap the auto and go manual so you could run real turbos with custom headers.
Re: RS6 Project 7XX
They are custom headers... and TTE turbos are a man's turbo, good for big numbers by all accounts. I'd try to stay with an auto, it's much more driveable leaving you more in the mid-range. Running manual with manual wastegate usually leaves you inside the massive turbo threshold... waiting.lswing wrote:You are correct!TTE Si wrote:No numbers as yet only just run in the motor and have on a safe map. Due to finish off soon.
Re: RS6 Project 7XX
It's too easy to break an auto box with 550hp let alone 600+...there's really no space to go big down there without pulling the auto box. Sure it will be good, but the next step is obvious if they really want big power.
Re: RS6 Project 7XX
Bam's speaking from owning both an auto C5 and manual converted C5.
Re: RS6 Project 7XX
Exactly, 700+hp manual! Any serious driving with good power will pop an auto box quick. Personally I really like the auto for driveability. Each person I've talked to going for high hp was forced to ditch the auto due to space restrictions (turbo/headers) and obvious ability to hold up.SuprSi wrote:Bam's speaking from owning both an auto C5 and manual converted 7xxhp C5.
Re: RS6 Project 7XX
Yeah we know both sides of the gearbox. Its like you say drive ability. Lets see... If is a problem we will address.
Ill share pics soon im just going through 600 images...As few things we have done are a little different
Similar turbos at a less power spec, using smaller compressor we have done 900hp+ on e85 and 800hp on 102 fuel on the 3.0 V6 RS4 (all without wmi) Not saying we will do this here as many factors with rs6 engine and setup, but gives a idea. Also yes has twin BMC canister air filters and custom pipework.
Re: RS6 Project 7XX
TTE Si wrote
Hey Luke
Yes has a reinforced auto and Manual box standing by that been used in the car previously
Light Head work By PSR with uprated valve train
Ill update with some pics later just about to take the kids out
What has been done to reinforce the gearbox and by who ?
Hey Luke
- Mr Footlong
Re: RS6 Project 7XX
I have had the BMC CF canister filters before (XJR) and I very rarely hear anything positive about them. Using them by choice or because they are an easy fit currently? BTW, my eyes melted when they saw what had been slapped on the exterior of that car, sort it chap!
Current:
Gone:
Gone:
Re: RS6 Project 7XX
. . . and he's back!Mr Footlong wrote:I have had the BMC CF canister filters before (XJR) and I very rarely hear anything positive about them. Using them by choice or because they are an easy fit currently? BTW, my eyes melted when they saw what had been slapped on the exterior of that car, sort it chap!
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
- Mr Footlong
Re: RS6 Project 7XX
Like Herpes.
Current:
Gone:
Gone:
Re: RS6 Project 7XX
its supposed to stand out guys its not a normal RS6 i like it for being a bit mad fair play!
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
Users browsing this forum: Google Adsense [Bot] and 111 guests
