Power output
Power output
What's the most power that's been seen on a tuned rs4 without going down the supercharging road?
Mine is currently 338ps, would the sport cats or a cat delete pipe give much more?
Re: Power output
338? Just getting it to run right should get you 40 or 50 horsepower...
Do you mean 438?
Fastest NA I've seen was with a ludicrously expensive and elaborate German ram airbox. They claimed 470-480ps and it was a very quick car.
Do you mean 438?
B7 RS4 saloon Misano red, comfy seats, JHM tune & JHM full exhaust with cats and resonators - gone.
C5 RS6 Avant Daytona/Cognac - gone.
981 Cayman GTS Gray/Orange.
My youtube
My youtube
Re: Power output
You have an issue. Most likely a vacuum problem. Need to sort that out first and see what power you've got.
How long ago was the carbon clean?
With your mods and a recent carbon clean I'd expect about 440bhp. Maybe up to 450 with a cat delete. A sports cat won't make much difference if you already have the gutted precats as the standard cat is 200cell same as some sports cats (Milltek do a 100cell too though so slightly less restrictive). If the carbon clean was a year or more ago then I'd expect you to be around the 410 mark. But 338ps is well low (even with a vacuum problem). Do the valves on your milltek still work?
The most I've seen from a NA B7 is about the 450bhp mark which is pretty much the same mods you have but with no cats.
Re: Power output
How do you check if your engine needs a carbon clean ?
Re: Power output
Apologies, that should of read 438ps
Re: Power output
Carbon clean was only done in June last year, yes the valves still work perfect on the milltek, it's pretty loud, if I opt for the delete pipe then I might need to wear earplugs
Re: Power output
In that case, you might get another 10bhp from going catless but thats about the limit without charging.
Re: Power output
I only asked about the valves as it might be an indication of vacuum issues but now we know you have 438ps then all is good.Rs4reilly wrote:Carbon clean was only done in June last year, yes the valves still work perfect on the milltek, it's pretty loud, if I opt for the delete pipe then I might need to wear earplugs
Re: Power output
You need to get your car on a dyno and get a power test done, if your figures are low then it's time for a carbon clean, unfortunately every b7 rs4 needs this done, poor design by Audi.Harris. wrote:How do you check if your engine needs a carbon clean ?
Re: Power output
Cheers Mike, have you heard any with the delete pipes?MikeFish wrote:In that case, you might get another 10bhp from going catless but thats about the limit without charging.
Re: Power output
Rs4reilly wrote:You need to get your car on a dyno and get a power test done, if your figures are low then it's time for a carbon clean, unfortunately every b7 rs4 needs this done, poor design by Audi.Harris. wrote:How do you check if your engine needs a carbon clean ?
Oh right , id have to find someone in Essex to do it then
Re: Power output
You have a place near you in Essex Harris,called AMD,go to http://www.amdtuning.com & have a look.
B7 RS4 saloon,black,miltek,hi flo cats,MRC stage 2 remap,stage 2 manifold, CAF.
Previous,Z4m coupe,Tvr T350c,E46 M3 smg,R33 Nissan Gtr.
Bikes,Suzuki Gsxr 750,Kawasaki 600 ninjas.
Re: Power output
Thanks mate ,are they any good ?
Re: Power output
Theres a RS4 on ebay for sale currently, 480bhp n/a mrc tuned it claims. No mention of mods done however.
Audi RS4 B7 Saloon 456ps MRC
Audi S3 8P 310bhp Revo
Audi S4 B5 Saloon 504ps MRC
Audi S4 B5 Saloon 320bhp Revo
Audi A4 B7 TDI Saloon 215bhp R TECH
- Tile Diver
Re: Power output
447 PS for mine!!
- Attachments
- MRC Tuning.pdf
- (502.41 KiB) Downloaded 87 times
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 187 guests
