Just a quick one, if you get a 'TPMS' come up on the dashboard in yellow any ideas what it could be, everything i've been reading on TPMS is a flat tyre symbol, this is just the letters.
This was intermittent but now is every time the engine is running.
Thanks for the help in advance.
TPMS Fault
- orangepeel
- 1st Gear
Re: TPMS Fault
More than likely its the tyer sensors are on there way out some will probably be along and post a link up
Re: TPMS Fault
Had it on mine a few weeks back checked all the air pressure and then reset the readings for the TPMS in the menu and not had a issue yet. The other option is have the tyres tested for a slow puncture before isolating one of the sensors.
Re: TPMS Fault
Yeah I have checked all the pressures etc and tried resetting it to no avail, can VCDS pinpoint the issue? If so, does anyone live around the Epping area who has it and I could be cheeky and find out what the issue is?
